Coolant leak from bolt hole
Old Dec 7, 2005 | 07:16 AM
moparman's Avatar
This is odd. I've noticed since cold weather got here, and I let the car warm up, a small amount of coolant leaks from the top bolt hole on the passenger side of the water pump. It appears that once the thermostat opens, the leaking stops. Could this be repaired by draining enough coolant to remove the bolt, and coat it with some kind of no leak compound? Car is a '96 Formula.
Old Dec 7, 2005 | 07:36 AM
Re: Coolant leak from bolt hole
Probabably. You are supposed to use thread sealant on those bolts.
Old Dec 7, 2005 | 09:52 AM
OBE1 95Z28's Avatar
Like Shoebox stated, waterpump bolts require thread sealant. In addition, the bolt(s) may not have been torqued to the correct value and the fluid could be leaking from the waterpump gasket, just showing itself by the bolt.
Old Dec 7, 2005 | 03:06 PM
Victory Racing's Avatar
Torque them to 30ft/lb with thread sealant and you will be all good.
Old Dec 7, 2005 | 04:03 PM
moparman's Avatar
Turns out it wasn't the bolt hole. I took a million candlepower light out to the car, opened the hood, started the car and watched for the leak. It was the hose above it leaking. Tightened the clamp and solved it. The coolant was dripping right on top of the bolt head, making it appear to be coming from the bolt hole.
Old Dec 7, 2005 | 04:14 PM
Ya gotta love it
At least it was a simple fix.
Old Dec 7, 2005 | 04:31 PM
moparman's Avatar
Yes, I wish everything was as simple. I learned a long time ago to look at the simple stuff first. I didn't want to mess with draining any coolant or the bolt. It's cold here. That's why I took the light out, to see better.
Old Dec 7, 2005 | 07:14 PM
That light probably helped your hands stay warm, too.
Old Dec 7, 2005 | 07:44 PM
moparman's Avatar
Those lights will get hot. But, you can see!!!
maybe2fast
Mar 16, 2015 09:45 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
Joes96z
Dec 13, 2014 07:48 PM
dansam
Jul 20, 2002 01:10 PM
