355-383 machine work
Old Jul 23, 2004 | 05:51 PM
lostitall's Avatar
If I was to buy a block that was machined for a 383 can I still use it for a 355? Do they bore the mains for a 383? I know the block gets notched for clearance....anything else that gets special attention?
tia
Old Jul 23, 2004 | 11:58 PM
Formula03's Avatar
Re: 355-383 machine work
For a 383 they bore the cylinders .030 over same as a 355 so yes you could. The only thing that they do to the block for a 383 is bore the cylinders .030 and notch the sides. The mains are left alone. If you are using a 400 crank (instead of a aftermarket 383 crank) then the turn the crank down to 350 main specs.
Old Jul 24, 2004 | 12:02 AM
97WS6SCharged's Avatar
If you were using a 400 crank in an LT1, you would also need an adaptor for the rear main seal.
Old Jul 24, 2004 | 12:14 AM
Formula03's Avatar
Yeah thats true I was just throwing that in as when you would need machine work that would involve the mains.
Old Jul 24, 2004 | 12:41 AM
lostitall's Avatar
thanks guys for the information.
I really appreciate it!
Scottyboy
Feb 11, 2015 10:28 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
phoenix95
Jan 8, 2015 02:44 PM
chuyz28
Nov 25, 2014 11:14 PM
1LEThumper
Jul 14, 2003 12:45 PM
