350LT1 Tech
Old Aug 24, 2003 | 11:01 AM
siggesnake's Avatar
350LT1 Tech
Is ther any one ho has tech sheets for a camara94 350lt1
i want to now what kind of a cam shaft cast or foggd pistongs an so on
Thanks please
Old Aug 24, 2003 | 11:27 AM
94blackz14.2's Avatar
Here is a site that has some of the info that you are looking for.
http://www.f-body.org/tech/
Old Aug 24, 2003 | 03:12 PM
Cmr0z28's Avatar
....lay off the crack dude
Old Aug 24, 2003 | 03:57 PM
Cerwin Vega Fan's Avatar
Sorry but the LT1 is not a 350 cubic inch motor, it is a 349.
Old Aug 24, 2003 | 04:57 PM
Cmr0z28's Avatar
umm.......no. LT1 is 350, LS1 is 346.
Old Aug 24, 2003 | 05:15 PM
Fast_89rs's Avatar
you are all on crack
5.7 LT-1.....later Dudes
Old Aug 24, 2003 | 05:39 PM
Lyle A's Avatar
5.7L x 61.025 = 347.8425 cu.in. I don't do dope. For all practical purposes, it's a 350. Conversion factors here.
Old Aug 24, 2003 | 06:39 PM
Cmr0z28's Avatar
89RS just got OWNED
Old Aug 25, 2003 | 01:50 AM
Fast_89rs's Avatar
716.62 cylinder volume...349.8ci.......
Old Aug 25, 2003 | 09:39 AM
Lyle A's Avatar
I would say that we are both right there. I didn't know what he exact volume was although it can vary from car to car depending on what pistons or head work or even rod length is.
Old Aug 25, 2003 | 09:48 AM
Displacement does not vary with rod length.
Displacement is defined as a function of bore and stroke, and does not vary with piston type (unless "type" happens to mean something other than stock bore) or head work. You can only change "displacement" by changing bore or stroke.
4.00 bore X 3.48 stroke = 349.85ci = 5.733 liters
When displacement is stated in terms of "three significant figures", it is correct to round it to "350".
Old Aug 25, 2003 | 09:57 AM
Lyle A's Avatar
Well I'm learning something new every day here. Thanks. But, doesn't rod length affect stroke? And, wouldn't piston height also? I'm not a master mechanic so please explain.
Old Aug 25, 2003 | 10:02 AM
No, rod length does not affect stroke. It affects how high the top of the piston is when it is at the top of the stroke. Piston "height"???? Do you mean a "dome" or "dish".... if so, the answer is no. Does not affect displacment. Affects compression ratio.
The only thing that causes the piston to move up and down in the bore is the "throw" on the crankshaft. That determines stroke. Nothing else. For any particular stroke length, you have to match the crank throw + rod length + wrist pin height to put the top of the piston exactly where you want it, but neither the length of the rod or the location of the wrist pin will affect displacement.
Old Aug 25, 2003 | 12:18 PM
Lyle A's Avatar
Understood, Thanks for the explanation.
Old Aug 25, 2003 | 05:28 PM
Fast_89rs's Avatar
guess I'm not owned after all hey fellas.....
Boss002
Jan 20, 2016 12:17 PM
Fatdog2
Sep 16, 2015 11:04 PM
RX Speed Works
Sep 11, 2015 03:31 PM
Boss002
Jul 24, 2015 10:47 AM
