3500 stall compatible with stock LT1?
Old Feb 10, 2006 | 09:31 PM
Envy987's Avatar
I was curious if anyone knows if a 3500 stall is compatible at all with the stock lt1 cam and such. I just need to run it for a few months untill i have the money to get my cam/heads and some other goodies.
Old Feb 10, 2006 | 09:57 PM
96m6lt1's Avatar
Re: 3500 stall compatible with stock LT1?
should not be a problem at all in fact it will wake it up a bit
Old Feb 10, 2006 | 10:40 PM
sssalah's Avatar
I think it's too much for a stock cam, if anything it'll make it slower. You'll have a very narrow rpm range to play in.
IMHO, just leave the stock stall in until you're ready to stick in the new cam.
Old Feb 10, 2006 | 10:56 PM
Envy987's Avatar
thats what i was worried about, i didnt really wanna wait till i have my cam to get it tho since both the stall, and my head/cam package are expensive
Old Feb 11, 2006 | 01:31 AM
96m6lt1's Avatar
chances are the converter will not stall at that rpm anyway.
Old Feb 11, 2006 | 08:28 AM
LameRandomName's Avatar
I'm using a 2800rpm 9.5" Edge that stalls at 3000-3100 rpm and I still have the stock cam, albeit with bolt-ons. I'm also in a heavier car.
I would recommend the Edge 9.5 if you're more interested in straight line acceleration, but I would hesitate to suggest a 3500rpm converter.
However, if you are more interested in "road-race" type of quickness, then keep the stocker; because it'll give you better response.
Old Feb 11, 2006 | 09:16 AM
chevy94c's Avatar
I am driving around on a 3200 stall right now. Not bad at all with the stock cam.
96capricemgr's Avatar
I KNOW the fast bolton guys will disagree with you on this both b-body and f-body and the b-body cam runs out of steam even earlier than the f-body, the weight will help them stall higher too.
Old Feb 13, 2006 | 03:51 PM
Yeah, I picked up almost a second with my converter on the stock cam.
Noenav
Mar 1, 2019 07:38 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
