34 MAF/MAP signal low - high vacuum
Old Jan 31, 2007 | 08:51 PM
bg552's Avatar
Scanned the car yesterday and got this reading. Replaced the MAP sensor today and got the same code thrown in my face. What is up?
Old Jan 31, 2007 | 10:09 PM
mrmint69's Avatar
I would check the MAF also.
Old Jan 31, 2007 | 10:29 PM
Do not use a "generic" code list.... that code applies only to the MAP sensor on the LT1's. Shoebox has the LT1-specific list on his website:
http://shbox.com/1/Dtcs.htm
DTC 34 = Manifold Absolute Pressure (MAP) sensor circuit (signal voltage low, high vacuum)
The code sets when the PCM sees a reading indicating a vacuum higher than the engine is caable of producing. Check the harness connector. They dry out and crumble, making intermittent contact with the sensor pins.
Old Feb 1, 2007 | 11:03 AM
bg552's Avatar
I copied the code exactly as it read on the code scanner.
The clip on the harness connector is broken off but i am positive that I is still connected all the way. I'll take it apart again today and look for corrosion or other damage.
Old Feb 1, 2007 | 11:28 PM
That would be a "generic" code list. But if that's what you want to use, go for it. No sense using Shoebox's list and getting it right
Old Feb 2, 2007 | 01:17 AM
bg552's Avatar
i was saying i didnt use a code list in the first place because the scanner told me what it was. after i got the code i looked online and found the exact code.
Old Feb 10, 2007 | 09:49 PM
ZachXSmith's Avatar
whats going on with the black bitch? What codes is she throwing???? Do I have to come fix my old car?
timmy39120
May 8, 2015 11:41 AM
4586
Apr 27, 2015 06:08 AM
lt1matt
Mar 21, 2015 07:35 PM
Jan 23, 2015 01:13 PM
My94RedZ28A4
Aug 11, 2002 10:04 PM
