32lb injectors and stock fuel pump???
Old May 4, 2004 | 10:39 PM
Hawk350's Avatar
question....I had a mail order tune on my pcm and it was programmed for the new cam. I am installing 32lb injectors but wont be able to install the new 255lph fuel pump for a week or two. Will the 32lb injectors work for the time being with teh stock pump? or with the car run lean? Maybe a silly question but I am just curious.
Old May 5, 2004 | 02:06 AM
QCKZ28's Avatar
what fuel pressure is the #32 injectors rated at?
what brand injectors?
the car will run like crap with bigger injectors if the pcm isnt reprogrammed.
as far as the stock fuel pump, it will work fine as long as it is healthy.
jesse
Old May 5, 2004 | 06:45 AM
Hawk350's Avatar
they are rated for 32lbs I guess....
HectorM52
Jul 30, 2017 11:46 AM
RiverMutant96
Jan 30, 2015 09:21 AM
spearous
Jan 12, 2015 11:03 AM
ANDYZ28
Dec 29, 2014 09:13 PM
