30 lb injectors to small???
I was doing a little datalogging and my injector rates are going to 95-96% at WOT. Should I upgrade to 36's or will my 30lb SVO's be okay? I haven't got on the dyno yet, so I really don't know how my A/F looks. My O2's are reading 890-930 at WOT. Any suggestions?
The injectors should be fine for what you are doing. I use an adjustable fuel pressure regulator to fine tune the AFR with smaller injectors and it works fine for me. I ran 11.15@121mph on stock injectors with about 55+psi of fuel pressure. I just upgraded to 30#'s since I need more fuel with the bigger solid roller cam, more compression and more RPM. Later Clint
carguyshu
Jan 22, 2017 11:19 AM
Perry93TransAm
Aug 20, 2002 11:23 PM
