Holley TB TPS% issues
Old Jul 2, 2007 | 11:08 AM
Tricked-Out-Toy's Avatar
Ive got a weird issue. Im getting a TPS high voltage code and not sure how to cure the problem. while opening the throttle body manually and watching the voltage and % open on datamaster I can see the votage moving nice and smoth from about .83 to 4.98-5volts. the problem im having is at the point when datamaster says im 100% the Throttle body is not 100% open. when I push it past the 100% point it drops the throttle body position % to 4 and it stays at 4 for a while even after you return the TB back to the closed position.
How do I adjust the TPS sensor to read 100% when the throttle body is actually open 100%?
Old Jul 2, 2007 | 11:16 AM
mattbailey's Avatar
Slot the tps sensor holes and adjust it where you want it.
Old Jul 2, 2007 | 01:33 PM
Why didnt I think of that! lol thanks
Old Jul 2, 2007 | 01:57 PM
mattbailey's Avatar
No problem, I had to do it myself.
Old Jul 2, 2007 | 03:11 PM
That's how everyone does it.
Potent77
Mar 16, 2022 12:13 AM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
