3/8 vs 7/16 stud
Old Sep 12, 2007 | 07:12 PM
  #16
dangalla's Avatar
you should def use a thread sealant on the threads, and again if you dont already have the rockers i would get 7/16 just for added insurance
Old Sep 12, 2007 | 09:00 PM
  #17
rskrause's Avatar
Moderator
Originally Posted by 95z28man
I bought the heads from someone on the boards. They are LE2's with a Comp Cams camshaft, .510/.520 lift. I'm assuming that the springs are the Comp Bee Hive Springs mentioned on eportworks.com under LE2.
You do not "need" the 7/16" studs. IF you are replacing rockers anway, get them. Otherwise, don't bother.
Rich
Old Sep 12, 2007 | 10:18 PM
  #18
Dave1980's Avatar
I talked to Lloyd about that same subject because of the comp spring issue. He started using PAC springs months back, but the website has not been updated I guess. I would see if you can find out when they were done by him if possible.
I already had 3/8 rocker arms , so I am just going to go with arp studs. They are a much better metal compared to the standard crap.
Old Sep 13, 2007 | 02:45 PM
  #19
95z28man's Avatar
Ok, well I have to get the rockers anyways, so I will spend the extra $40-50 for the added insurance.
Thanks a lot
Old Sep 13, 2007 | 03:03 PM
  #20
Joe B's Avatar
Yea, No Doubt, ARP 7/16 studs....and permnatex #2 the "NON-drying" sealant on them (Not silicone RTV, like some use).........3/8 studs not only commonly break, but they also flex MUCH more than the 7/16 studs ever do.....when a person is buying rockers anyway, Not spending the extra 30 bucks for ARP 7/16 studs is crazy............Joe
Old Sep 14, 2007 | 07:43 PM
  #21
Shimaze's Avatar
Question off topic: 1.6 rockers
Thanks for the info, it seems as if the best idea is 7/16 even though I don't need them.
Just want some advice:
My '94 Z28 just turned the 100k mark yesterday. when upgrading to 1.6 rockers, do I need to go with new, slightly stiffer springs? The car revs to 5k with no problems. I am not ready to replace the cam, but I just want to get a little more power out of it. The 1.6 rockers should be like a slight cam upgrade ...correct? The bigger rockers will help the engine suck more air/fuel and make my other mods work better ...any opinions?
Old Sep 14, 2007 | 07:48 PM
  #22
seawolf06's Avatar
It's not necessarily that the springs have to be stiffer (they do) but the stock springs can't handle the additional lift from the rockers.
Old Sep 14, 2007 | 07:59 PM
  #23
JimboManJones's Avatar
FWIW I broke a factory 3/8s stud with less then 85k miles on my car. That was with just bolt-ons. Probably not the norm, but why chance it over 40 bucks right?
Old Sep 30, 2007 | 11:06 PM
  #24
grandpacaprice's Avatar
What came stock on the Alum heads? 3/8 or 7/16?
Old Sep 30, 2007 | 11:21 PM
  #25
rskrause's Avatar
Moderator
All stock SBC screw in rocker studs have a 3/8" diameter on the portion that screws into the head.
Rich
Old Sep 30, 2007 | 11:28 PM
  #26
Rich
I would assume the stock top is 3/8 too?
Old Oct 1, 2007 | 12:21 AM
  #27
speed_demon24's Avatar
Rich
No they don't, the part that screws in is 7/16
Old Oct 1, 2007 | 01:04 AM
  #28
What about the top part on a stock stud? Thanks
Old Oct 1, 2007 | 01:22 AM
  #29
Stl94LT1's Avatar
3/8
Old Oct 1, 2007 | 06:21 AM
  #30
rskrause's Avatar
Moderator
Dyslexia (and lack of sleep) strikes again!
Rich
13qtr
Oct 28, 2016 08:11 PM
Z Power
Sep 19, 2015 11:19 PM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
JCSWS6
Jul 19, 2015 06:47 PM
