3/8 vs 7/16 stud
Old Sep 11, 2007 | 02:10 PM
95z28man's Avatar
3/8 vs 7/16 stud
Right now my LE2 heads have 3/8" rocker arm studs, but no rockers. My question is, should I keep the 3/8" in and just get the rockers and be done with it, or get all new 7/16" studs and rockers? Is there a big difference between the two?
Old Sep 11, 2007 | 02:14 PM
Don 97 SS's Avatar
Well, the difference is just 1/16th. But IMHO, that little bit larger stud makes me feel more comfortable at higher RPMs. But I am no engine expert. I'd swap to 7/16s.
Old Sep 11, 2007 | 02:35 PM
wrd1972's Avatar
Yes do it, cheap insurance if you have to get roller rockers anyway.
Old Sep 11, 2007 | 03:31 PM
96 mikez28's Avatar
7\16, once you hold them up to a 3\8 stud you'll smile and be happy you bought them
Old Sep 11, 2007 | 06:29 PM
95z28man's Avatar
All for the 7/16. That convinces me. Thanks
Old Sep 11, 2007 | 06:38 PM
dangalla's Avatar
one more for the 7/16
only an extra 40$ and they are more stable at high rpm's
Old Sep 11, 2007 | 08:03 PM
Shimaze's Avatar
OK, but do you have to change anything for the 7/16 stud? Like drill the heads out more? Or is the only difference above the part that screws into the heads? Is the stock aluminum heads capable of screw in, 7/16” studs with no mods?
Old Sep 11, 2007 | 08:05 PM
dangalla's Avatar
all you need are the studs and 7/16 rockers
Old Sep 11, 2007 | 08:12 PM
mzgp5x's Avatar
I went from 3/8" to 7/16" stud. The bottom thread is 7/16" corse thread on all. Fine thread on top. Also, went from Crane gold 3/8" SA to the ProMag and PR plates due to larger trunion bearings. I have AFR heads, and, stock LT1 heads are the same. I reccomend a lock-tite on the stud. The Comp RR rocker locks were tall and forced me to use a Proform valve cover. Dress up the engine bay some. B.
Old Sep 11, 2007 | 08:41 PM
seawolf06's Avatar
I really think the important thing is to go from stock studs to aftermarket (ARP). Whether you get 3/8 or 7/16 I doubt makes much difference considering the forces and how they act on the rocker/lifter. However, if you're going to get some new studs and haven't yet bought rockers, you might as well get the larger ones.
Old Sep 11, 2007 | 08:44 PM
rskrause's Avatar
Moderator
Use Never-Seize on the stud and torque it to spec. What springs do you run and what is the lift? The typical HR setup will do fine with 3/8" studs. Waste of $$$ if you don't need em, IMHO. It's not that they aren't stronger, 'cause they are (~36% stiffer) but whether it is needed.
Rich
Old Sep 11, 2007 | 08:48 PM
dangalla's Avatar
i was told to use thread sealant due to the studs slightly protruding into the intake ports on the le heads
Old Sep 11, 2007 | 08:53 PM
rskrause's Avatar
Moderator
If they do, then use sealant. Don't use Loctite.
Rich
Old Sep 11, 2007 | 11:33 PM
SSTAT's Avatar
dangalla- love that avatar. That rods gonna need some ointment...
Old Sep 12, 2007 | 07:09 PM
95z28man's Avatar
Rich
I bought the heads from someone on the boards. They are LE2's with a Comp Cams camshaft, .510/.520 lift. I'm assuming that the springs are the Comp Bee Hive Springs mentioned on eportworks.com under LE2.
