3.8 to LT1 on 96, AC question
Old Jan 13, 2012 | 11:31 PM
brandonppr's Avatar
I'm in the process of doing the swap right now. I was going ahead and hooking up the ac dryer and noticed that the line from dryer to the firewall wont match up. Its like they both have male ends. Am I doing something wrong or does the 3.8 have a differnt part inside the box on the firewall?
I have this diagram and the one I am trying to hook up is line 19.
Old Jan 13, 2012 | 11:41 PM
Re: 3.8 to LT1 on 96, AC question
Yep, the L36 (3.8L) system looks different in that regard. It does not use an expansion valve like the LT1. The LT1 and L32 (3.4L) are the same (as the diagram shows).
Old Jan 14, 2012 | 12:07 AM
brandonppr's Avatar
DOH! What does the expansion valve do? Can I get a line made to adapt to it or do I have to swap out the stuff inside the fire wall? I think I aready scrapped all those parts from the donor car.
Old Jan 14, 2012 | 09:05 AM
Maybe an a/c shop can help. One system uses an expansion valve setup and the other uses an orifice tube. I don't know how you convert one to another.
Old Jan 14, 2012 | 09:53 AM
brandonppr's Avatar
What is the part called that is inside the box? Also what is invovled in changing it? Can it be changed from the engine side or do you have to get under the dash inside?
Thanks for the help.
Old Jan 14, 2012 | 03:01 PM
The rectangular block on the LT1 system is the expansion valve. I don't know if the evaporator (radiator thing inside the box) would need to be changed. I'm not an a/c expert. That is why I suggested some input from a shop.
http://shbox.com/1/ac_system_L36.jpg
Old Jan 14, 2012 | 10:51 PM
brandonppr's Avatar
It appears to be all one piece. I just got an AC delete pulley from Advance Auto. I decided to just leave the AC out for now. From what I read the evaporator can be changed by only removing the PCM, then the top half of the box and then the pass side header. I may put it back on later, but for now I just want to work on getting my engine swap done and getting this car going.
Thanks for the imput.
http://www.ebay.com/itm/93-94-95-96-...item3f1240304b
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
bernie1951
Dec 10, 2014 10:03 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
