3 & 5 crossed
Old Jan 13, 2007 | 04:46 PM
ZL1modified's Avatar
3 & 5 crossed
after dropping my motor out i noticed that the 3 & 5 wires were crossed...
how much does this affect my performance?
i put about 10k on my engine this way...
will my et drop at all?
and could this be why i had a misfire code?
Old Jan 13, 2007 | 07:29 PM
95LT1conv's Avatar
i cant believe you were actually able to run it that long without noticeing something was seriously wrong. im pretty sure that would have been your problem
Old Jan 13, 2007 | 07:44 PM
Bersaglieri's Avatar
Err...I hope you dont have anyone doing performance work for you, cause if they are, they dont know crap.
-Dustin-
Old Jan 13, 2007 | 08:03 PM
http://videos.camaroz28.com/recentvi...5132da08a9.htm
i made this video when wires were crossed... the car runs real freakin rich and has a bit of backfire... i thought it was just the borla...
can you tell something is wrong? i really couldn't...
yeah, i pretty much do my own work now... unless it is the differential or the tranny....
Old Jan 13, 2007 | 08:04 PM
mrmint69's Avatar
I had 2 reversed and i could not get the car out of the garage. The vibration was like someone plugged the exhaust pipes with bananas. I was thinking it was running on 1/2 the cylinders but maybe the ones that are wrong makes all the difference. Mine must have been the 2 worst to be reversed.
Old Jan 13, 2007 | 08:06 PM
-Dustin-
i had someone change my plugs and wires when i just got the car and didn't feel like sqeazing in there...
Old Jan 13, 2007 | 08:41 PM
razor02097's Avatar
when I first bought my 89 RS it had 3 and 5 crossed. It ran rich and popped a lot. Also smelled and got horrible gas milage. After I changed the plugs and wires during normal service I noticed the problem, after switching them back and making sure all the other wires where in the right place I took it for a drive and HOLY CRAP what a difference! I just thought it was cause it was a 305 and had over 200K miles that it was so sluggish but I was wrong.
Old Jan 14, 2007 | 09:03 AM
i'm curios to know why it wasn't running crappy...
is this something that will take ~.1, .2, .3 seconds off the 1/4?
i know that it is hard to give me a perfect answer, really looking for someone to chime in that had same problem...
Old Jan 14, 2007 | 09:33 AM
Guest47904's Avatar
Guest
No offense but......
Here's your sign
No muffler will make it run rich.
Didn't you notice the performance decrease, running rich and backfiring after the wire change that wasn't there before the wire change???????
A line lock would make a skateboard look good. But when you let off the brake and took off, it sounded down on power.
I would be concerned about the health of the 2 cylinders in question. Souping is bad for the cylinder walls. Time for a borescope!!!!!!!
Old Jan 14, 2007 | 05:14 PM
[QUOTE=speedygonzales;4341964]No offense but......
A line lock would make a skateboard look good. But when you let off the brake and took off, it sounded down on power.QUOTE]
i have no line lock...
getting one though...
the cameraman was rushing me... i tried to let off the gas so i could launch...
i'm not a pro...
Old Jan 15, 2007 | 03:13 PM
Here's your sign QUOTE]
can you tell me why it wasn't running like ****?
Old Jan 15, 2007 | 03:16 PM
Didn't you notice the performance decrease, running rich and backfiring after the wire change that wasn't there before the wire change??????? QUOTE]
i got the wires changed as soon as i got the car, along with the 3:73's i previously had and borla... so no i didn't notice...
Old Jan 15, 2007 | 03:20 PM
danhr's Avatar
I would be too embarrassed to even post that on any site....
You have more ***** than me, my friend.
Old Jan 15, 2007 | 03:24 PM
sbs's Avatar
sbs
Old Jan 15, 2007 | 03:33 PM
TobyZ28's Avatar
Curious as to which wires were crossed Car running with 1 cylinder not firing was noticable within seconds as soon as i hit the road..
