3.4L To LT1 Swap - NOW NO START
Maybe you all can help me. I have a 95 3.4L and I did a swap to a 94 LT1. Everything went fine and I believe that I hooked up all the approprate connectors but the car won't start. It turn over again and again but doesn't fire. There is no spark. I did all the Chilton's tests and it doesn't look like the coil is getting power. Can anyone help?
Re: 3.4L To LT1 Swap - NOW NO START
be sure you have all ur connections IN ur OPTISPARK...specially the one on TOP of it.....check around there and on ur coil!
double check all that stuff.....i did that before and found out my opti spark wasnt all plugged in...
Randy
Randy
I am at work but if I remember correctly there was two. Also, all of the LT1 engine harness connectors mated correctly with the in dash harness in the passenger side footwell.
Jul 4, 2005 05:00 PM
