3.4 M5 to 5.7 A4 swap--- Whats needed?
Old Feb 26, 2010 | 10:39 AM
brandonppr's Avatar
I got two cars one is a
3.4L 1996 M5 convertible Camaro
and the other is a
5.7L 1996 A4 Ttop Camaro
The LT1 car is wrecked in the front, but has all the wiring intact.
What all do I have to change over from the LT1 car?
Do I have to change inside wiring? Steering column? What about the fans? All of the AC?
I know I have to swap the pedals, PCM, gauge cluster, Transmisson, gas tank and maybe fuel lines. I am going to change the rear because it has disc brakes, so I might have to change out the brake components and lines as well.
I have a brand new radiator for it.
Old Feb 26, 2010 | 11:17 AM
You will need the K-member from a 4th Gen LT1. May need beefier front springs.
There is a "sticky" on the V6 Tech forum that covers swaps.
Old Feb 26, 2010 | 06:49 PM
brandonppr's Avatar
ahh. I hope this k member is ok. I know something is wrong with the a arms because they are bent expecially on one side. The other side may be ok but the shock was broke. The spring is in a bind hopefully its not bent. The side that has the bent a arm has a strait spring.
I noticed the 3.8L I have looks to have the same dual fans. The ones on the LT1 car are broke.
I'll check the V6 section also thanks.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
