3.4 M5 to 5.7 A4 swap--- Whats needed?
I got two cars one is a
3.4L 1996 M5 convertible Camaro and the other is a 5.7L 1996 A4 Ttop Camaro The LT1 car is wrecked in the front, but has all the wiring intact. What all do I have to change over from the LT1 car? Do I have to change inside wiring? Steering column? What about the fans? All of the AC? I know I have to swap the pedals, PCM, gauge cluster, Transmisson, gas tank and maybe fuel lines. I am going to change the rear because it has disc brakes, so I might have to change out the brake components and lines as well. I have a brand new radiator for it. |
You will need the K-member from a 4th Gen LT1. May need beefier front springs.
There is a "sticky" on the V6 Tech forum that covers swaps. |
Originally Posted by Injuneer
(Post 6281681)
There is a "sticky" on the V6 Tech forum that covers swaps. I noticed the 3.8L I have looks to have the same dual fans. The ones on the LT1 car are broke. I'll check the V6 section also thanks. |
