3/4" or 1" header bolts
Old Dec 12, 2003 | 12:25 AM
ROWYCO's Avatar
Intsalling my jet hots this week. I just got my percy's gaskets and they are thick as hell. I was wondering if I could get away with using the 3/4" bolts that came with my headers or if I need to get some 1" bolts.
Old Dec 12, 2003 | 01:12 AM
97WS6SCharged's Avatar
Most header bolt manufacturers recommend a 1 inch bolt for aluminum heads.
Old Dec 12, 2003 | 01:20 AM
revtime's Avatar
do yourself a favor and get a good set of 1 inch bolts.
Old Dec 12, 2003 | 01:23 AM
I switched to Breslin Splitlocks. I haven't tightened a header bolt in months now.
Old Dec 12, 2003 | 01:26 AM
QCKZ28's Avatar
i will second that
get the 1"
Old Dec 12, 2003 | 02:01 AM
96 WS6's Avatar
The Percy's will crush down a little bit to give you more room, however get 1" bolts. I know this for a fact, it will be very hard to start 3/4 inch bolts with those gaskets.
I am using ARP 1" non-locking bolts as nobody has had problems with these and my crappy stage 8's were waste because it's too hard to get those crappy locks off (not to mention if you want to take the header off or tighten the bolts). Basically your two choices are Breslin Splitlocks which IMO are the best option but are 60 bucks or the ARP 1" bolts. I like the ARP's because they have a 12 pt head and they are 5/16 so you can fit a closed end wrench around the head and it won't touch the primary (very good for tightening bolts).
Old Dec 12, 2003 | 10:54 AM
ZyberMunster's Avatar
Get the 1 inchers ....1in. Stage 8's+MAC's+OEM GM gaskets = no retightening in months here!!
Laterzzz...
Old Dec 12, 2003 | 11:54 AM
T/A#4's Avatar
I used the one inch ARP S.S. bolts with the 5/16 hex head. Tried to use Stage 8 but not enough room to clear the 1 3/4" tubes of the Jet Hots. May be looking for another self locking bolt that will clear?
Old Dec 12, 2003 | 12:53 PM
ticket_me_redz's Avatar
Anyone got a part number for the 1 inch ARP bolts handy?
Old Dec 12, 2003 | 01:13 PM
IslandZ's Avatar
I bought some stainless steel 1" bolts with Allen head, and on the driver side I could get them all on, and tightening the whole driver side takes about 2 minutes. The passenger side I couldn't get them to fit in like 4 places
1" definately better.
Old Dec 12, 2003 | 01:28 PM
96 WS6's Avatar
ARP-400-1210 from summitracing
These bolts are GREAT! Way better than my Stage 8's.
Old Dec 12, 2003 | 02:01 PM
GREGG 97Z's Avatar
I used 1" 12pt ARP's with my SLP headers, they worked great. I don't know why anyone would use a 3/4" bolt on aluminum heads when you can use 1". I would think there is a much greater risk of stripping the thread with the 3/4".
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
