2pc rear main seal adapter
Old Jul 20, 2007 | 09:08 PM
11secgen's Avatar
i have a forged 2 pc crank ,but a lt-1 block.id love to be able to use my 2 pc crank on my lt1.does anyone know if the the 2 pc rear main seal adapters from ebay work?i also have a set of 6.0 L19 eagle h beams so all i need is a set of mahle pistons,some gaskets,a cam and springs and #36 injectors.it funny how a blown headgasket turns into 450 hp built.
Old Jul 20, 2007 | 09:11 PM
dangalla's Avatar
i have been told the adapters are very prone to leaking so if your gonna do it i would not get an ebay model, spend the couple extra bucks on a good one
Old Jul 21, 2007 | 10:56 AM
chrism400's Avatar
Absolutely do not buy an EBAY reject adapter. I learned the hard way. Buy a name brand one like the GM or Moroso. It also needs to be properly aligned with an alignment tool you can make yourself or purchase. If your seal leaks, the motor has to come out and be completely disassembled. We ended up drilling aligning holes for dowel pins to be installed to keep it from moving around.
Old Jul 21, 2007 | 12:22 PM
cnorton's Avatar
I've used a variety of the adaptors available with good success over a period of several years. I prefer the Moroso unit but I've also used the one from Competition Products in Oshkosk, Wisconsin with no problems. Be sure that the gasket sealing the adaptor to the back of the block is sound. DO USE the correct alignment tool!!! The ONLY time I had any leak was when I used a good adaptor but tried to center it without the alignment tool.
I just checked the Goodson online catalog and I see that they sell the tool for less than $25. I had one machined out of billet steel in the interest of making sure that it's round and durable.
c
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
carl.froehlich
Mar 13, 2015 12:38 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
97 RedSS
Jun 10, 2003 07:58 PM
