are the 28 lb ls1 injectors good for my setup?
Old Feb 6, 2004 | 08:37 PM
MonkeyManZ28's Avatar
i have a fresh 355 with p & p heads and intake, hot cam, and full bolt ons. i saw slp had a set of 8 ls1 28lb injectors for sale for about 100.00. thats a great price, will they do ok with my setup?
Old Feb 6, 2004 | 08:45 PM
simple's Avatar
LS1 injectors are rated 28lbs/hr @ 58psi or so
LT1's (94-97) are rated 24lbs/hr @ 43.5 PSI
LS1 injectors at the LT1 fuel pressure work out to be about 24psi or so ruffly the stock rating
for an extra $50 or so you can pick up a used set of 30# SVO's that at the LT1 FP 43.5psi will be about ~32lbs/hr
i would pass on the LS1 injectors with your mods!
and for $199 you can get them from here (scroll down) http://www.gefracing.com/Merchant2/m..._Code=50INTAKE
ZPaul2Fresh8's Avatar
No, they won't flow @ 28lbs with LT1 fuel pressure(43psi). They flow 28lbs. @ LS1 Fuel pressure (58 psi).
Get some accel or SVO 30#, you'll be set.
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
