255walbro, high or low press.?
Old Feb 24, 2004 | 08:14 PM
IrocSS85's Avatar
here's my new setup.
ported heads. 233/239 .570 cam, 1.6rr., 52mm tbody, ported intake, midlength headers, offroadpipe, 3:73 gears, 3000 stall, ank alot of other small stuff.
well, I searched on walbro, and read about 6 pages. didnt find exactly the answers to my questions.
1)which is better for LT1? high, or low press. walbro's?
2)what will fuel press. be w/stock fpr and either high, or low press. pump?
3)if I end up w/high press. pump, and fuel press around 50psi, why not just adj. tune instead of spending another $100 on afpr? (getting a custom dyno tune anyways.)
4)what fuel press. is the racetronix w/stock fpr?
5)how do you open the bucket? cut it?
TIA
chris
Old Feb 24, 2004 | 08:18 PM
blazzinbird's Avatar
You will be fine with low pressure
Old Feb 24, 2004 | 08:43 PM
Robs97Z28's Avatar
I second that!
Old Feb 24, 2004 | 11:03 PM
IrocSS85's Avatar
well, thats what I thought, but that doesnt answer any of my questions. thanks for the input though. anyone care to answer any of my questions? esp. #2 and 3?
chris
Old Feb 25, 2004 | 07:44 PM
Racetronix's Avatar
The pumps upper end pressure capability is not a concern unless you are running very high pressures / FI.
The Racetronix F-LT1 system is based around the HP pump as they are more efficient (draw less power at a given pressure) and have proven in our books to have a better reliability factor.
There is only about $10.00 difference between the LP and HP pumps so it is hardly worth marketing both when the HP does a better job of covering both bases.
Remeber it is you regulator which governs system pressure.
Old Feb 25, 2004 | 10:35 PM
IrocSS85's Avatar
well, thanks for the reply. thats all I need to know I guess.
chris
May 21, 2015 01:04 PM
4586
Apr 27, 2015 06:08 AM
Jan 23, 2015 01:13 PM
My94RedZ28A4
Aug 11, 2002 10:04 PM
funina91ss
Aug 6, 2002 11:20 PM
