230/236 xfi
Old Jul 16, 2006 | 06:36 PM
chy20k1's Avatar
230/236 xfi
I'm looking to buy it, but comp sells it on a 113 lsa, probly +4 as most of them are, id have to call and see. anyways, would there be anything to gain by ordering it on a tighter lsa or maybe not as advanced(assuming it is +4) maybee a 108 lsa and no advance? dont really know, thanks -Dave
Old Jul 16, 2006 | 08:23 PM
1racerdude's Avatar
Re: 230/236 xfi
Your LSA and ICL will depend on your head flow and CID and the RPM's ya want to turn.
It's NOT just a matter of saying I want a 108 or 112 or???.
That's a pretty big cam unless ya got heads and compression.
FWIW a 4* advance or any advance helps the bottom end TQ.
Old Jul 16, 2006 | 10:03 PM
chy20k1's Avatar
Re: 230/236 xfi
cars got stock heads, 11.0:1 compression. i just got a friends motor running in my car. stock motor with an 847. its nowhere near as bad as i thought it would be. the cam seems like it makes more than enough bottom end torque to me. i have a smaller cam that was gonna go in my motor but after driving the 847 around a bit id rather use my small cam as a paperweight
Old Jul 16, 2006 | 10:08 PM
1racerdude's Avatar
Re: 230/236 xfi
The biggest thing ya are doing is raising the shift points with a big cam,not necessarily making more HP. Torque is off down low also.
The 847 isn't the best cam either.
Ya want a cam to shine put a gear in it.
Old Jul 16, 2006 | 10:16 PM
1racerdude's Avatar
Re: 230/236 xfi
BTW has that car got a tune for an 847??
Old Jul 16, 2006 | 10:26 PM
chy20k1's Avatar
Re: 230/236 xfi
yes sir it has a tune. runs pretty good too.... dies every once in a while though lol
eventually my motor will get heads. id like to get something that will take advantage of them when i do get them rather then swap cams.
Old Jul 16, 2006 | 10:39 PM
1racerdude's Avatar
Re: 230/236 xfi
Unless ya get the compression up it might not run as ya planned.
Old Jul 16, 2006 | 10:45 PM
chy20k1's Avatar
Re: 230/236 xfi
it can go as high as 11.8:1 right now depending on what pistons i buy.
Old Jul 16, 2006 | 11:09 PM
1racerdude's Avatar
Re: 230/236 xfi
Flattops with 4CC reliefs,a "0" deck and 54CC's(stock) will put ya more than that on a 356 if ya want. Ya need to figure your DCR before ya get to wild about ordering anything.
Old Jul 16, 2006 | 11:15 PM
chy20k1's Avatar
Re: 230/236 xfi
the block was not zero decked. it was decked enough to clean it up. im assuming for now that its gonna be .020 in the hole(since the "stock" deck height is supposed to be 9.026). gonna use a .026 gasket. heads were ccd at 53 ccs. 5.7 rod. 4.030 bore. stock 3.48 crank.
Old Jul 16, 2006 | 11:27 PM
z2894droptop's Avatar
Re: 230/236 xfi
yes sir it has a tune. runs pretty good too.... dies every once in a while though lol.
It isnt a very good tune if it dies. The 847 is a nice cam, but your car should not die with a good tune.
Old Jul 16, 2006 | 11:29 PM
1racerdude's Avatar
Re: 230/236 xfi
Ya can run more than 11.8 if ya want to. I am running 13.3 static on pump gas with a 9.1DCR but I built it do do it and 12-12.5 would not hurt it if the DCR is below 9.0.
Old Jul 16, 2006 | 11:33 PM
chy20k1's Avatar
Re: 230/236 xfi
honestly, its got 5 gallons of good gas i just put in it, who knows how much gas was in there while it was sitting for 6 months and the fuel pressure is a little high cause the stock regulator cant handle the racetronix pump. i think once i get that stuff taken care of it should be ok. its only been running for a couple days. it only dies when i turn sharply. well see what happens. it also has a hair of hesitation off idle, still looking into that. also, i said it had a tune, never said it was a good one, only said the motors running pretty good
Old Jul 16, 2006 | 11:35 PM
chy20k1's Avatar
Re: 230/236 xfi
im honestly thinking i might just get some flattop mahles, put the shortblock together to see how much they are in the hole and then get a custom cam made up for it. i do plan on daily driving it
Old Jul 16, 2006 | 11:37 PM
1racerdude's Avatar
Re: 230/236 xfi
OK then.
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
KamikaZ28
May 28, 2015 12:45 AM
Fastbird93
May 22, 2015 08:28 PM
R_Andersen
Apr 30, 2003 11:59 PM
Ken95Z28
Mar 3, 2003 10:35 AM
