230/236 XE cam on stock heads and stock stall...
Old Dec 15, 2004 | 03:33 PM
fesgali's Avatar
It says to use the cam with aftermarket heads and stall. What would be the effect of that cam on a stock stall and stock heads.
Would the springs, lifters, rocker arms, etc. have to be changed?
Old Dec 15, 2004 | 03:41 PM
grygst76's Avatar
Re: 230/236 XE cam on stock heads and stock stall...
It will be like eating ice cream thru a straw
will more then likely stall in drive, you'll have no power, or you will need to rev the crap out of it to take off
Old Dec 15, 2004 | 06:27 PM
Z06Z28's Avatar
Contact some Supporting Vendors for what you need...
Just to name a few....they will help ya out with a package...
Thunder Racing
Speed Engineering
Old Dec 15, 2004 | 07:31 PM
grygst76's Avatar
Thunder Racing
Speed Engineering
very true, you'll need upgraded heads, if you cannot afford it you'll need new springs, retainers, pushrods. You will definitely need a bigger stall like 3000 minimum.
When choosing a cam, remember you have to match more then just what the specs say.
Almost forgot, you'll maybe need gears too.
Not trying to sway your decision, just schooling you a little as what is involved with going with a cam like that..
Go with a cc305 and you will only need pushrods, springs, retainers, and a tune.
Old Dec 15, 2004 | 07:34 PM
WayneE's Avatar
I'd worry about emissions in MD, Mohsen.
Old Dec 15, 2004 | 09:57 PM
fesgali's Avatar
I already have a prob with that, took the test 4 times last time and i still had to "encourage" the guy before i passed...Hows it goin Wayne
Old Dec 15, 2004 | 11:29 PM
dust6928's Avatar
with that cam the car will probably try and walk thru the brakes. when it lopes it will creep
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
Catmaigne
Dec 25, 2014 12:16 PM
