230/236 with cm-612 springs.. good or not?
i'm going to run the xe 230/236 and i have a set of cm-612 springs. i'm trying to decide if i should add a rev kit to be safe or are these springs good as is???
thanks
mike
thanks
mike
Re: 230/236 with cm-612 springs.. good or not?
yes, they are rated that, yes people run bigger, does that mean that people don't ever have valve float? no it doesn't. alot of people have problems with valve float on the XE grinds due to the aggressive ramp. i just wanna be sure the 612's can handle the XE lobes.
have you dyno'd your TA?
I have the same setup: 230/236 w/ 612's. Also, here's my dyno from the weekend: http://www.fuelslut.net/hosting/uploads/Dyno.jpg
With some tuning I'm hoping to break 350hp. We didn't even get a clean pull to 6k rpms because it was breaking up, so we didn't even reach where the cam peaks. I'm hoping I see the torque go up a little too b/c it seems kinda low.
Ryan
Ryan
what kind of head work have you had done???
i'm working the heads extensively. hoping for more than 350 myself. your a/r don't look too bad, too bad you don't have an m6, i'd have you mail me your tune! lol.
thanks, looks like these springs may work alright after all, now i just need some 1.6 rr's, and a good clutch!
mike
mike
mike
mike
Ryan
cool, it would be a start, so maybe with my ported castings, i'll get closer to my goals. just mail the bin file to limige1@aol.com. i think that would give me a good start.
Originally Posted by madwolf
233/239/112 w/612. No float to 6600 where I ended the run. Do I feel safe with them? No, but they do work.
My cam: 237/245 dur. , 582/292 lift , 113lsa I have same problem.. My heads came with AFR's springs ,but 220lbs (for solid roller cam) I still don't know which springs should I go..
I'd go with comp 918s. Lift isn't necessarily just what causes float. I cam with .550 lift can float valves while a cam with .600 lift won't, you also have to take into account the ramp rates of the cams. With that being said the 918s should work great, they were designed to work with ls1 cams, that majority of which have more aggressive ramps than lt1 cams.
thanks again guys, i've been reading alot of threads where people have valve float issues with this cam, i just wanted to be sure those springs were good enough before i bolted the motor together.
Magenta_Hearts
Mar 25, 2015 10:24 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
