230/236 cam track #'s
Old Apr 12, 2008 | 07:29 AM
Chuckels's Avatar
Got some numbers after putting a cam in the ole' LT1 a couple of weeks ago. The car is still full bolt ons with a cam only (230/236 .545 .555 112 lsa)
I launched at 5900 rpm and my shift light was set to 6100 rpm but I think I'm gonna raise that to 6200 next time. I got a littlel bit of spin on the lauch but not much.
60'-1.73
1/8- 7.80
MPH-90.0
1/4-12.20
MPH- 114.2
Its getting there, I think that its still got more in it though.
This was at capitol raceway in Crofton, Md
Old Apr 12, 2008 | 08:01 AM
1badasZ's Avatar
good numbers. i have the same cam but havent gotten to run it yet. i hope to have it back running before the month is out. hopefully i can run somewhere around that time too. i have that cam and LE2 heads. what kinda tune are you running?
Old Apr 12, 2008 | 03:09 PM
Chuckels's Avatar
I had a local tuner do it on a mustang dyno.
I never found too many people that posted numbers with this cam so I figured I'd throw them out there for research.
Old Apr 12, 2008 | 05:27 PM
RedScreaminMachine's Avatar
Damn good numbers! That's almost identical to the cam in my LS1 (230/236 .551/.551 112).
How's the driveability? I might look into something like that for my LT1...
Old Apr 12, 2008 | 05:53 PM
Chuckels's Avatar
This is my first cammed car but I think its still really driveable. Its a little of a pig off idle but the drivablity tune wasnt finished compleately.
Old Apr 12, 2008 | 06:24 PM
2000GTP's Avatar
Very nice numbers, pretty good gain with the cam.
Old Apr 12, 2008 | 06:45 PM
my96z's Avatar
Whats your suspension setup? Thats a damn good 60.
Jeff
Old Apr 12, 2008 | 08:52 PM
Chuckels's Avatar
Jeff
You think the 60' is good, I really want to be cutting like 1.65's at least
I've got Moser 12bolt w/ spool & 4.11, spohn lca's, chromoly sfc's, and QA1 R's w/ 300lb springs. I dont have a front swaybar either. I think I can get the 60' time down some with a set of rear shocks. My budget it tight so I might just use comp engineering shocks.
Old Apr 12, 2008 | 08:55 PM
LJM97Z's Avatar
Yeah, whats the suspention, is that on the stock rearend/gears
Old Apr 13, 2008 | 02:32 PM
97 6SPEED Z's Avatar
Thumbs up
I've had the exact same cam (Comp Cam XE 230/236 .544"I/.555"E w/1.6 rockers) in my car for over two(2) years now .... and my best ET and MPH are shown in my signiture.
Old Apr 13, 2008 | 09:13 PM
neil350's Avatar
Good times, my friend had that cam with a set of ported factory casting LT1 heads.
Old Apr 13, 2008 | 10:02 PM
buzz12586's Avatar
I've gone 12.32 @ 114 with the cc503 (224/230 .503/.510) so it doesn't look like there is much gain with the 230/236 with stock heads. I'm sure once you port the heads there will be a bigger difference.
Old Apr 13, 2008 | 10:05 PM
PoloM6's Avatar
did you have ported heads???, anyone know what wuold be the difference in time at the 1/4 with a ported heads???
Old Apr 14, 2008 | 09:08 AM
Cool
No, my 12.21@115.42 run was on stock LT1 heads with the bolt ons shown in my signiture.
Old Apr 14, 2008 | 11:38 AM
marshall93z's Avatar
Very good times with stock heads!!
