227/233, CC305 or CC306
Old Jul 29, 2004 | 03:02 PM
My 97 Z28's Avatar
Will be running stock headed. Which cam is best for my needs, daily driver. I want good lope. how comparable is the 305 to 227/233? Same with the 306.
Old Jul 29, 2004 | 03:22 PM
disco192's Avatar
Re: 227/233, CC305 or CC306
Ive owned both the 305 and 306 cams. The 305 honestly doesnt lope at all. The 306 chops rather hard though. For driving around on stock heads, i would recomend the 305. I loved the TQ on the 305. It was quite the TQ monster. I could cruise at 40 in 6th without any cam surge at all.
My new car ran stock heads for a while on the 306 cam. It wasnt the most fun car to drive because of cam surge and lack of TQ. I have LE heads now and there is much more TQ and it runs alot better.
Take that for what its worth.
-Stu
Old Jul 30, 2004 | 01:21 PM
TransAmGT94's Avatar
i agree with stock heads you dont want to go with the 306 you would have to swap springs for either cam you get best choice spring is the ex 612-16
Old Jul 30, 2004 | 02:23 PM
EddieP's Avatar
In the past, I've run both the CC305 and CC306 with stock heads, and definitely preferred the CC306. I didn't mind the aggressive lope, and my only other complaint was the surge from around 1600 to 1900 rpm. Long tubes, exhaust, CC306 got me solid 12's at 114+ mph on stock heads. CC305 was too tame for me.
Old Jul 30, 2004 | 02:46 PM
ScreamnChicken's Avatar
Same here. Just swapped out the 305 for the 306 and long tubes(had shorties). Went from 298rwhp/316rwtq to 351rwhp/365rwtq on stock heads through an A4. If you don't mind some surge and extra attention, then get the 306. Plus if you ever get your heads worked over, you will see that much more of a gain. Do it right the first time so you don't have to do it over again like I did.
Old Jul 30, 2004 | 03:46 PM
Black_Z28's Avatar
Who tuned your car Nick? Also, how long did it take you? And if you don't mind what did it run you? Thanks.
Old Jul 30, 2004 | 03:58 PM
Pasky's Avatar
What do you mean by surge at 1600-1900 rpm?
Old Jul 30, 2004 | 04:05 PM
Cole, this is Formula94(Nick Choban). Tuned up at hi-tech. Cost was $225 for 7 pulls. I think for a first time dyno tune it is like $350 and after that it is cheaper. Trust me, Brian knows his stuff and is very helpful. Plus he is probably about as far away from you up in St. Cloud as he is from me in Eagan.
Old Jul 30, 2004 | 04:16 PM
EddieP's Avatar
Just that - the engine will surge when you are cruising in that RPM window. If you've never felt cam surge, it's like the driver is getting on and off the gas over and over.
Old Jul 30, 2004 | 08:48 PM
Pasky's Avatar
Oh, okay, I thought that happened at idle, won't a extra vacuum reservoir help that out?
Old Jul 30, 2004 | 09:27 PM
Somnambulist's Avatar
the 224/230 is another choice.
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Russ95Z28
Apr 23, 2015 01:55 PM
langtown77
Dec 20, 2002 11:27 PM
dhirocz
3rd Gen / L98 Engine Tech
Jul 23, 2002 05:03 PM
