227/233 .560/.569 Dyno Graph
Old Dec 22, 2003 | 04:10 AM
ravigogna's Avatar
Talking 227/233 .560/.569 Dyno Graph
Finally got my car dynoed
intake is still stock
The dyno guy said that he thinks the afr is still a little lean.
Modifications
Hooker Longtubes with true 2.5" dual exhaust w/bullets
227/233 .560/.569 lift (with 1.6 rockers) 111lsa
1.6 comp cams pro magnum RR
comp cams type r Roller lifters
Comp cams chromemoly pushrods
345rwhp 339rwtq
what do you guys think
dyno graph
air fuel ratio graph
Old Dec 22, 2003 | 04:23 AM
aintno6's Avatar
nice dude. The car has a really nice flat torque curve. How does the car hook up on the street?
Old Dec 22, 2003 | 08:11 AM
GetaZforgetGT's Avatar
Nice numbers.
Is that with or without ported heads?
Old Dec 22, 2003 | 08:45 AM
quicksilver97ta's Avatar
Nice dyno graph. The a/f graph does look kinda wacky, up and down like that. But the WOT fueling table in the PCM is like that, up and down all over the place, not sure about '93 but the rest of them are.
Old Dec 22, 2003 | 09:38 AM
96lt1Camaro's Avatar
Is this the XE227 cam? Awesome numbers man!!!
Old Dec 22, 2003 | 10:54 AM
93ZM6Tally's Avatar
Good Numbers
I have the same cam and have similiar numbers, (In Sig). Our mods are similar as well except that I have a set of locally P&P heads. Would you happen to have SAE corrected numbers? The curves also look similar but I was running a good bit richer than you, in the 11.8:1 area.
Old Dec 22, 2003 | 11:22 AM
Antz97ZNJ's Avatar
Thumbs up
nice numbers
Old Dec 22, 2003 | 12:52 PM
whontime's Avatar
Nice numbers. This may seem like a crazy question, but I notice that your graph says that the dyno run was in 3rd gear. Is 3rd the gear commonly used for dyno pulls with an M6 car? I know when I did my pulls they were all in 4th gear. Does this make any difference?
Old Dec 22, 2003 | 03:36 PM
N2OpwrdTA's Avatar
Wink
whontime....lol, you beat me too it. I seen that earlier but didnt reply cause I had to leave that instant. I cam back and you asked it. I would think 4th gear should be used. In a 6speed, 4th gear is the 1:1 gear ratio...which is what you want for an accurate pull.
Old Dec 22, 2003 | 06:03 PM
brain's Avatar
nice numbers! The difference between 3rd and 4th shouldnt be more than 3 - 5 hp, not a big deal.
ravigogna, can you post the dyno file? I would like to do some comparisons to my dynos with runviewer. Thanks!
Old Dec 22, 2003 | 07:16 PM
sc93's Avatar
those seem like great numbers to me! I was looking at that cam too
are you still running stock heads??
Old Dec 22, 2003 | 07:17 PM
97Z-M6's Avatar
you need a tune bad that A/F chart is crazy. you need to spend some time on the dyno just for tunning.
and there will be more than 3-5 hp difference between 3rd and 4th you should always dyno a m6 in 4th gear.
Old Dec 22, 2003 | 08:26 PM
ravigogna's Avatar
The dyno was done in 3rd because my rearend is a 2.73 and forth gear takes too long to have an accurate pull.
The heads are home ported and polished. All I really did was take out the casting lines in the intake and port match it to the intake, then polish the combustion chambers and exhaust ports.
Brian, i can e-mail you the runviewer file, send me your e-mail address. My e-mail is ravigogna@sbcglobal.net
The current tune is from Alvin at PCM for less. I sent him the air fuel ratio chart and a datamaster file that the dyno guy made for me and he is sending me another chip.
Hope it fixes my Air fuel ratio wackyness.
Old Dec 22, 2003 | 10:39 PM
GhostZ's Avatar
Looking good!
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
