225 + degrees HELP
Old Jul 31, 2005 | 02:05 AM
omatter67's Avatar
225 + degrees HELP
If anyone out there has a solution to my problem I would appreciate it. I put in a new opti spark, new water-pump, new radiator, and new thermostat and my car is still heating up close to the red. I don't understand why I did everything I could. I have a toggle set up to run my fans continuesly, I bled the antifreeze lines after I did all the new installs. I don't know what else there is too do. Is there a sensor that controls the temperature that I don't know about. Anyone with a tip I seriously would appreciate it. thanks alot
Old Jul 31, 2005 | 03:02 AM
white/blackss's Avatar
Re: 225 + degrees HELP
sounds like either you didnt bleed it all the way or you have a blown headgasket.
Old Aug 1, 2005 | 02:18 PM
akathom's Avatar
Make sure that you have the correct thermostat installed. Reverse cooling system, you know.
Old Aug 1, 2005 | 02:37 PM
LagunaS3's Avatar
I realize you put a new radiator in the car, but did you also put a new cap on the radiator? Also, are you losing any coolant? I would take my car to a mechanic and have the cooling system pressurized. That way you can find out if there are ANY leaks anywhere.
Zach
RUENUF
Mar 13, 2016 03:37 PM
plattted
9
Sep 20, 2015 11:23 AM
Henson071
Sep 18, 2015 04:01 PM
damnyankee36
Sep 9, 2015 07:06 PM
13qtr
Jul 19, 2015 05:30 PM
