Accel shorty spark plugs
Old Jul 31, 2005 | 05:18 PM
1QuikTransAm's Avatar
Does anyone know what the length difference is between the accel shorty plugs (P526S) vs. a NGK TR55 (or equal length) plug?
I have another thread posted right now concerning spark plug wire boots burning and these shorty plugs are one of my thoughts.
Thanks,
Adam
Old Jul 31, 2005 | 09:57 PM
matt65's Avatar
Re: Accel shorty spark plugs
Link 3rd picture down on rt side of article may help.
Old Jul 31, 2005 | 09:59 PM
JBird33's Avatar
Wow Adam, considering they are like $12 apiece I'm not sure that small of a difference is going to buy you anything...what do you think man?
Old Jul 31, 2005 | 10:16 PM
Tsar's Avatar
Damn its like 4 or 5 milimeter difference. This is gonna sound dumb but cant you do something with the boot?
Old Jul 31, 2005 | 10:53 PM
matt65- thanks for the link man.
I don't know what i'm going to do about my wires. I jacked the car up today to get underneath and check out most of the spark plug boots. All are good except for #5. I think the main reason it burned was because the heat sleeve wasnt around the boot very well. I've got some spare boots off a couple of my old taylor wires that i'm going to use in place of the burned one, for now at least.
But if i have anymore problems, i'm just going to bite the bullet and get the shorty plugs and accel 9000 wires.
Old Jul 31, 2005 | 11:20 PM
mr_will's Avatar
the accel shorty plugs are about 1/4" shorter than delco's but the problem with the accels i cant find the shorties in the heat range i need
and to add to this autolite 104's are a shorter plug too not real short but shorter than most plugs
Old Aug 1, 2005 | 07:05 AM
matt65's Avatar
No problem, Keep us updated.
Old Aug 1, 2005 | 10:12 AM
salty's Avatar
Say a fellow wanted to only install shorty plugs in 2 spots where clearance was minimal, and wanted to use ngk tr55's for the remaining 6 plugs. Would that cause any problems?
Old Aug 1, 2005 | 10:17 AM
1racerdude's Avatar
NO
Well if it was a Pro Stock.....
Shouldn't hurt a thing.
Old Aug 1, 2005 | 01:28 PM
JBird33's Avatar
Originally Posted by robvas
$12 each? My whole set of Accel shorty plugs was $20 at Autozone
Thats what he said they cost earlier when he looked them up. Those aren't my numbers man
Old Aug 1, 2005 | 02:39 PM
valter's Avatar
Moroso blue boots withstand much higher temperatures. There also MSD High temperature boots which are good too. Together with sleeve, they almost survive a contact with a ceramic-coated primary. If you have any air gap, you will be fine.
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
