224/230 aluminum head vs stock iron head
Old Mar 22, 2005 | 07:43 PM
sw89lt1's Avatar
i have a stock 95 impalla motor in my 89. i'm about to put some lightly ported aluminum heads and a 224/230 cam in, and i was curious about how much difference i will notice. any one have any experience with this or any idea.
Old Mar 23, 2005 | 07:14 AM
whatsup's Avatar
Re: 224/230 aluminum head vs stock iron head
I'm assuming you have all the supporting mods....( headers, CAI, exhaust, etc)? Are you running 1.6rr's with that? You are not running stock springs...are you? You will need a tune!! Now with all that...you should notice a very decent gain. I hear the iron heads flow a little better but the weight you save on the aluminum equals that out. That cam is as big as you would want to go on stock heads...i run it and love it!! Don't know all the differences from the Impy motor to the f-body. I would assume injector, TB, and compression would be the same..??
Old Mar 23, 2005 | 12:36 PM
sw89lt1's Avatar
yes i will be running shorties 1.6 rr and new springs.
Old Mar 24, 2005 | 02:29 PM
sw89lt1's Avatar
ttt
Old Mar 24, 2005 | 02:39 PM
AdioSS's Avatar
West South Central Moderator
big power increase
Old Mar 24, 2005 | 02:58 PM
tanker's Avatar
one way to find out
1) install cam with 1.6rr and shorties on iron head
Dyno tune it
Post the results on board
2) Flow your ported aluminum heads
swap iron heads to slightly ported aluminum
Dyno tune it
I would be very interested to see the results
Back to your original question. Iron heads do flow better than aluminum ones, so probably a slight port job on aluminum heads will just make them flow the same as iron heads
And by swapping heads on your stock short block you will be running a risk of spinning a bearing since there is an opinion that changing heads without rebuilding the bottom end misaligns the bearings due to re-stressing the block. There were a couple posts about it in detail.
However, iron heads are heavier and they dissipate heat less. That's why there is 9c1 version of Caprice- to cool better
InfernalVortex
Jan 17, 2015 09:35 AM
Catmaigne
Dec 25, 2014 12:16 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
CobraEatr
Jul 29, 2002 11:46 AM
