Is 20w 50 safe for a LT1?
Old Jun 5, 2008 | 09:05 AM
  #46
ulakovic22's Avatar
Originally Posted by pro94lt
Do you really think running the 20w 50 is a horrible idea? I'm no pro on oil and even engine building or bearing clearances but if i have 20psi at 5 grand that tells me that the oil is being pushed past the bearings to easy, and the heavier oil will slow down that process causing the higher oil pressure reading. Am i on the right page or not? All i want is for my engine to last as long as it can for the least amount of dollar invested. How wide are the clearances on the bearings for you guys running the 50 weight?
You're on the right page. Your engine is really worn out so the bearing tolerances are greater and the oil is flowing through very easily now, thus less pressure. The thicker oil is obviously harder to push because of it's weight and like you said, it's harder to push through the bearings so it's causing higher pressure readings.
What matters here though is volume, your pump can't change the volume of oil it pushes, it physically can't, like a water pump for a given RPM it will push a certain amount of oil. I honestly don't think it matters one way or the other what oil you run. You might be a little better off running a thicker oil but it's hard to say one way or another if you'll see a difference in bearing life because of it.
Old Jun 6, 2008 | 01:01 PM
  #47
jammer94's Avatar
to each his own...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jan 23, 2015 01:13 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
