heat problem
Old Apr 17, 2004 | 02:20 PM
pappasmerf18's Avatar
heat problem
my car is fine when moving but the fans dont turn on i replaced my fuse for the fans nothing changed what else or should i just make them manuel and leave it at that
Old Apr 18, 2004 | 06:28 AM
slopokrodrigez's Avatar
Does the primary fan kick in when you turn on the AC?
Old Apr 18, 2004 | 10:20 AM
i think soo
Old Apr 19, 2004 | 09:08 PM
Well if the primary does come on with AC. The temp sensor must be bad.
Old Apr 20, 2004 | 06:57 AM
well my fans work now that i put them on a switch so its the sensor then. this is the one located on the water pump right. any one know the part number
Old Apr 20, 2004 | 08:08 AM
The fans don't come on until 226°, so if it is not getting much hotter than that, things are normal.
Cam's maro
Mar 24, 2015 08:09 PM
kksi
Feb 17, 2015 10:41 PM
Jan 23, 2015 01:13 PM
Injuneer
Dec 15, 2014 09:36 AM
big dave
Sep 4, 2002 06:53 AM
