2 questions
Old Aug 2, 2005 | 09:58 AM
1crazylt1's Avatar
2 questions
1. if i do supercharger or turbo setup do i need my pcm tuned rite away b4 i drive it?
2. i can run my stock fuel pump with ethier of these setups for alittle bit the upgrade
Old Aug 2, 2005 | 10:58 AM
gmr speed's Avatar
Re: 2 questions
If you do either of these I would not recommend driving your car. You can start it ,but try not to see any boost. If you boost it wile driving . Your fuel will be all over the place most likely lean when you see boost, and your timing will be wrong for boost pressure.
Old Aug 2, 2005 | 11:02 AM
WS Sick's Avatar
Re: 2 questions
If you do bring a freind with a shovel and a wheelbarrow to pick up the peices (in answer to either question)
The tune can only be bandaided by an FMU and timing retard along with colder plugs that is with a very very healthy pump. The pump cannot be bandaided around after it reaches it's limit.
Old Aug 2, 2005 | 11:18 AM
1crazylt1's Avatar
Re: 2 questions
so i would need a tune,fmu and timing retard
anyone no were i can find these n any speacial ones that are good..
Old Aug 2, 2005 | 12:13 PM
1crazylt1's Avatar
Re: 2 questions
so doing a fmu is the wrong way?..
i mean iam gunna get a turbo kit for 1300 comes with everything but fmu timing retartd n fuel pump
if i buy all of this seperate it wouldnt work? and do i need to buy new injectors?
Old Aug 2, 2005 | 12:16 PM
Usmuscl398's Avatar
Re: 2 questions
Where you gettin this kit, what DOES it include?
Old Aug 2, 2005 | 12:26 PM
Zaddiction27's Avatar
Re: 2 questions
are you forgetting that you have to forge your engine or you will have a turbo chassis and thats about it. also your rear end may need to be replaced
you need:
forged crank
forged pistons
forged rods
driveshaft
rearend 12bolt or 9"
beefed up tranny
ect............
some you can slack on but if you want to do it right then your looking at more than just 1300 for your turbo setup.
Old Aug 2, 2005 | 12:31 PM
Usmuscl398's Avatar
Re: 2 questions
That all depends on how much boost and how much pwr hes running, (a4) deff need a beef up, but ne thing past 400 rwtq u need a rear end, end of story!
1crazylt1's Avatar
Re: 2 questions
it includes the turbo,intercooler,pipeing,headers,all the lines,bov,oil pan..its not like iam running crazy boost for all that forged sh**..iam gunna run like 4-5 psi till i get money to do engine work..
Old Aug 2, 2005 | 03:37 PM
1crazylt1's Avatar
Re: 2 questions
just found out the the kit comes with fmu and timing retart all i need is fuel pump n a tune..
Old Aug 2, 2005 | 11:27 PM
1racerdude's Avatar
Re: 2 questions
Vortec has been running FMU set up's for years. They build um and sell um they should know what will work.
Run plenty of FMU's on Fords with no problems if set right.
A dyno tune will net more HP and get everything set right including the FMU and A/F ratio.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
