2 bolt to 4 bolt
Old Oct 24, 2009 | 11:02 PM
stephenpen's Avatar
2 bolt to 4 bolt
I'm thinking of getting a set of the 4 bolt caps for my 2 bolt LT1. How much machine work is it to install ? I found an Eagle set for $89 are they OK?.
I would like to run more nitrous but I'm a little worried about the 2 bolt letting go. How much do you think it will cost when I'm done. parts and labour
Old Oct 25, 2009 | 12:05 AM
matLT1's Avatar
Typical total cost is $400-500. This includes parts and machining costs.
Old Oct 25, 2009 | 02:59 AM
unfaded's Avatar
it cost me around 500 without parts.
Old Oct 25, 2009 | 03:42 AM
MikeGyver's Avatar
i was quoted around 600
Old Oct 25, 2009 | 11:43 AM
stephenpen's Avatar
Is this something I should bring to a lt1 specific shop or can I bring it to any good machine shop. I'm north of the border so there is not many f-body shops to chose from and there not cheap. I was told if not done right the block can easily be wrecked.
Old Oct 25, 2009 | 03:33 PM
chevyjeff's Avatar
Any competent machine shop can do it. They are the same as a standard small block chevy.
Old Oct 25, 2009 | 03:54 PM
red 95 z28 lt1's Avatar
i paid about 500 for this and i believe it included the caps but im not 100% sure
Old Oct 25, 2009 | 04:07 PM
87Aerocoupe's Avatar
It's usually $500 plus the cost of the caps because after the outer holes are drilled and tapped the mains have to be align bored and align honed and the labor for all of that usually eats up $500. I like Pro Gram billet main caps myself.
Old Oct 25, 2009 | 07:13 PM
jchevy's Avatar
When I built my motor it was $300 Labor to have it done. Its going to be a major pain in the *** unless you already have the motor out and torn down for some reason.
Old Oct 26, 2009 | 06:19 AM
bombebomb's Avatar
Cost me $500.
Eagle caps are fine, there are other choices which one's are the best is up for debate.
I have heard bad things about eagle cranks, but never their main caps.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
DETROIT_AREA_00_SS
Aug 21, 2002 06:38 AM
