2 bolt or 4 bolt?
Old Dec 21, 2006 | 06:29 PM
osolow's Avatar
2 bolt or 4 bolt?
I will be running a 6''rod 381 with ported heads le4 cam and all of the bolt ons. My question is how much HP will a 2 bolt hole up to? I will be spraying probly 200 shot and will probly have about 620-640HP at the wheels.
Old Dec 21, 2006 | 07:29 PM
Jlo's Avatar
Jlo
Go with a splayed main caps, I think that would be best for your set up, I'd say a 2blt can with stand 500-550n/a horse power but it's a different story with the juice more stress on the motor.
Old Dec 21, 2006 | 07:34 PM
SS RRR's Avatar
2 or 4 bolt you at least want billet caps. especially with the mannerisms of nitrous. i've read and heard way too many arguments to decide which one is better for any specific build. for my application (SR 396) i am going w/ splayed just out of personal choice.
Old Dec 21, 2006 | 07:41 PM
Jlo's Avatar
Jlo
I went with straight caps and arp studs.
Old Dec 21, 2006 | 11:25 PM
TransAm396's Avatar
Just stud it.
Old Dec 22, 2006 | 01:35 AM
SS RRR's Avatar
Originally Posted by TransAm396
Just stud it.
you would trust stock caps on a 200 shot?
yeesh...
Old Dec 22, 2006 | 01:38 AM
TransAm396's Avatar
yeah, they worked fine with a 150 shot.(know from personal experience)on a bone stock motor, I dont see why an extra 50shot would hurt esp with the added protection of the studs.
Old Dec 22, 2006 | 02:33 AM
SS RRR's Avatar
had a friend w/ a 383 on a 100 shot who screwed up a cam bearing, we pulled the engine apart and all except the outer main caps were broken in half. on a motor w/ stock stroke it may be fine. a stroker motor will create more cylinder pressure which will create more pressure on the crank and with a hard hitting shot of nitrous the caps may not stand a chance.
Old Dec 22, 2006 | 08:14 AM
RE AND CHERYL's Avatar
There's a world of difference between a stock motor on a 150 shot and a LE4 setup on a 200 shot. I'd use studs on a stock rebuild. With wht your doing I'd install splayed 4bolt caps. You can NEVER go too strong on the bottom end.
Re'
Old Dec 22, 2006 | 08:23 AM
rskrause's Avatar
Moderator
Four, for sure.
Rich
Old Dec 22, 2006 | 09:26 AM
osolow's Avatar
what should it cost for only labor(install splayed caps and line bore)???
Old Dec 22, 2006 | 10:12 AM
TransAm396's Avatar
about 400 maybe more depending on who does it to splay and fit the caps to the block and I think 140 to line hone it...plus parts.
Old Dec 22, 2006 | 10:18 AM
osolow's Avatar
any1 know of a good shop in or around Dallas, TX? I live about 60 miles SE of dallas in cedar creek lake.
Old Dec 22, 2006 | 10:25 AM
kline454's Avatar
this topic seems to come up ever week, You should be fine with studs, thats what i did on my 383 all forged, with 150-200 shot and the shop that did the work on the block siad it would be fine, and if you read super chevy they have a 406 with studs and they where saying it will be fine, and the 2 bolt is stronger than the 4 bolt conv. (not splayed) and think on how much h.p people are putting out on 2 bolt blocks with 4 bolt cap conv. SPLAYED mains is over kill in less you are pushing like 30psi or spraying 350 shot,
Old Dec 22, 2006 | 10:38 AM
Jlo's Avatar
Jlo
But how much HP are you pushing on motor and with the nos??
