2.73 gear swap
i have a 96 z28 a4. with 2.73 gears. i would like to change them to 3.42 gears for the 2 series carrier. do i need a new abs reluctor or any thing else to do this. any info is appreciated.
thanks
thanks
I just did this switch from a 2:73 to 3:73, make sure you buy a series 2 ring and pinion or you'll have to buy a spacer for it to workwith the series 2 carrier. The only thing i had to buy where a shim kit and spacer.
What spacer are you referring to?? All you need is a shim kit.
Jul 4, 2005 05:00 PM
