1st start fail
Old Feb 19, 2004 | 09:30 PM
Liquid Teal's Avatar
1st start fail
ive noticed a few times lately when starting my car first time of morning or after its been sitting a day or 2....it starts right uo, but quits. the second hit at it if i accelerate upon starting....it will do ok, but gas fumes are strong and theres a little fuel related smoke from exhaust that quickly burns away....what gives ?
thanks,
ps
have also noticed slow idle....
Old Feb 19, 2004 | 10:07 PM
JDBlaze85's Avatar
possible faulty coolant temp sensor. check the CTS reading before you crank her up in the mornin. you'll need a scanner or measure the resistance and voltage directly on the sensor.
also possible a faulty idle air control motor.
Old Feb 19, 2004 | 10:17 PM
thanks...
what kind of readings should I have ?
Old Feb 19, 2004 | 10:18 PM
Another possibility is a bad fuel pressure regulator. Check the vacuum control hose for fuel contamination.
Might be a leaky injector, too.
Old Feb 19, 2004 | 10:21 PM
sounds like id be better of to go to a dealer for a diagnostic....
but they like to play "sensor games"...
importkiller94
Jan 17, 2015 09:03 PM
squarehead
Jan 15, 2015 07:02 PM
simple
Aug 2, 2002 03:30 PM
