1st or 2nd gear burnout?
Old Feb 17, 2004 | 06:52 PM
SlickBlack Z's Avatar
Like the subject says...which is better and why? And what RPM do you dump the clutch at to get the tires spinning?
Old Feb 17, 2004 | 06:54 PM
cndctrdj's Avatar
why not both?
Old Feb 17, 2004 | 06:57 PM
Good point, man.
Old Feb 17, 2004 | 11:41 PM
LimitedEd1LE's Avatar
Do a burn out in 2nd gear when at the track. You can get more RPM and more velocity when you do a burn out in 2nd gear.
Old Feb 18, 2004 | 01:14 AM
Heatmaker's Avatar
Advanced Member
Why not both...
I love that... remember playing with the Z and seeing how far I could go doing that...Lots of Fun!!!!!
poor tires
Old Feb 18, 2004 | 02:02 AM
atljar's Avatar
I do 3rd
Why not shift? Because its really hard to keep the car in the box while shifting. You want to get you tires spinning hard in water, roll out a little, heat them on pavement. Once they start to hook you will hear them squeal and will pull rpms down. Off brake and roll out spinning.
Old Feb 18, 2004 | 02:13 AM
InjectedSS's Avatar
Originally posted by atljar
I do 3rd
I agree, 3rd gear here also!
Old Feb 18, 2004 | 02:29 AM
unTAmedLS1's Avatar
stock clutch= does not do burnout in 4th gear haahah I did first to second and second to third but 4th just melted clutch ...it was time anyway though and thats partly why I did that
Old Feb 18, 2004 | 03:41 AM
rskrause's Avatar
Moderator
When I was running an M6 I would start in first and shift to second. However, I was using a line lock. Without the line lock I would just start in second.
Rich Krause
Old Feb 18, 2004 | 05:17 AM
browneye97ss's Avatar
Ya, 1st or 2nd for me. Depends on what I'm feeling like at the time. Agree with unTAmedLS1 on burning up the clutch though. This would explain why my SS got put up 2 months early for winter. Oh well, this summer it will be pulling out with either a new SPEC 3 or McLeoud to play with. If ya can't pay to fix then don't break I guess.
Biggiebound
Apr 20, 2015 07:16 AM
Jul 4, 2005 05:00 PM
FormulaV8
Aug 17, 2002 11:32 PM
KASR_Z28
Aug 6, 2002 03:34 PM
Dragonballz28
Jul 21, 2002 01:21 PM
