1LE option
Old Oct 7, 2004 | 02:29 PM
  #16
jim88iroc305's Avatar
Cool Re: 1LE option
Originally Posted by shoebox
Where did you purchase the stuff? I had in the back of my mind that the 1LE shocks were yellow Koni's and very expensive. (might be wrong)
When I took the Koni DA's off my 96 and replaced them with SLP valved Bilsteins the price for all four SLP's was a "little" more the the cost of one Koni replacement shock. I broke the driverside front and noone was rebuilding them at the time. B. Strano told me might as well replace all four instead of doing just one, which is what led me to SLP.
The friggin dealer I bought car from couldn't even find the replacement Koni on his computer. I must of had over ten phone calls over the two days my car was in there. Finally told them to button it up with broken shock and drove to SLP in NJ where they did it in a few hours.
Old Oct 7, 2004 | 04:04 PM
  #17
TobyZ28's Avatar
Re: 1LE option
Originally Posted by White Knight
1LE isn't that much better I don't see why people buy that stuff. buy a good peice of hardware, cause basically your buying stock parts. If your shocks are blown then yea buy them but don't take off perfectly good shocks and put 1Le shocks on, from what i hear about them they feel almost no different other than a mental difference.
People are buying this "Stuff" because not everyone is fithy rich and can afford a new set of XXX aftermarket (and superior) springs/shocks.
http://www.gyrhead.com/special.htm
The above site is advertising 4 1LE springs, 4 1LE shocks and a 1LE swaybar for $189 + Shipping.
If your shocks are needing replacment and/or your springs are sagging and you just want to replace them this is FAR cheaper then buying the stock replacements and WAY more cheaper than buying a whole new set of XXXX aftermarket brand shocks/springs.
I have ~150,000 mi on these shocks and springs, none are blown and I don't mind replacing them with something that feels near stock if the price is right. The stockers lasted more than long enough for me...
Originally Posted by bozobuttz
therefore, 1LE front spring = part # 22077196. I dont see what all the confusion is about.
I think the confusion was that the people buying the front springs were under the impression that they were 360lbs 1LE front springs... when they were really getting what GM now calls the 1LE front springs which are equivilant to the stock front springs
Old Oct 7, 2004 | 08:22 PM
  #18
oneledvr's Avatar
Re: 1LE option
Originally Posted by 97-1LE
For your 96 you should have the folowing
2- front shock absorber- Koni Yellow 22140240
2- Rear shock absorber- Koni Yellow 22140228
intake elbow w/o silencer 25147187
2 front springs LT1 360 # 22132561
2 rear springs LT1 130/170 # 22132562
Transmission mount 22146231
Front sway bar 32mm 26032907
Front sway bar bushing 32 mm 26039956
2 rear lower control arss 10164151
rear panhard bar 10262147
right upper control arm 22145654
left upper control arm 22145653
right lower control arm 22156436
left lower control arm 22156435
If you have the decarbon shocks they are probally from 94/95 part #
front 22124758 or 22140190
rear 22124790 or 22140187
Yea, exactly what he said!
Kinglouui
May 26, 2016 11:05 AM
Ks0209
Oct 1, 2015 07:32 AM
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
