1LE option
Old Aug 9, 2004 | 03:50 PM
Red96Lt1's Avatar
1LE option
Just got my 1LE shocks and springs in today. They look almost identical to the old shocks and spings. Does this sound right, or did I just get screwed and buy factory shocks and spings?
Old Aug 9, 2004 | 03:53 PM
Steve0's Avatar
Re: 1LE option
The decarbons should be a bit thicker if they are the 1le versions. Hold them up to your stock shocks to compare sizes and verify.
As for the springs, they shoudl look pretty identical.
Old Aug 9, 2004 | 03:59 PM
Red96Lt1's Avatar
Re: 1LE option
Ok, thanks. I haven't done a direct comparison, but they just looked too similar.
Old Aug 19, 2004 | 05:04 PM
bozobuttz's Avatar
Exclamation Re: 1LE option
Can anyone confirm that the rear 1LE springs look exactly like the stock 1993 Z28 114lb/in rear springs? I compared them side by side and they look and feel exactly the same. And no, I dont have the 1LE code in my glovebox.
Old Aug 19, 2004 | 05:16 PM
Re: 1LE option
Where did you purchase the stuff? I had in the back of my mind that the 1LE shocks were yellow Koni's and very expensive. (might be wrong)
Old Aug 19, 2004 | 07:39 PM
bozobuttz's Avatar
Re: 1LE option
I'm assuming he got the 1LE deCarbons, not the Konis. I also bought the decarbons.
Old Oct 5, 2004 | 10:58 PM
Steve in Seattle's Avatar
Re: 1LE option
The 1LE springs should have 1 less coil than the stock ones. If "they look identical" they you got scammed.
I picked up a 1LE spring set recently and the rear springs were the only "real" 1LE units. The fronts are simply stock... what a rip.
Old Oct 6, 2004 | 11:25 AM
TobyZ28's Avatar
Re: 1LE option
http://www.gyrhead.com/special.htm
Are these the guys you got the springs/shocks from? They seemed like a really really good deal and I was about to buy a set myself. Then my opti blew =/
Old Oct 6, 2004 | 11:58 AM
Red96Lt1's Avatar
Re: 1LE option
Yeah, that's where I got it from. For like $150 shipped for shocks and springs.
Old Oct 6, 2004 | 09:04 PM
TobyZ28's Avatar
Re: 1LE option
http://tech.firebirdv6.com/1le.html
From the site above they posted the PN's as:
1LE Front Spring (GM p/n 22132887, 360lb/in, 63 N/mm) on 94 and up Fbodies.
1LE Rear Spring (GM p/n 22132889, 130-170 lbs/in, 23 to 30 N/mm)
From the gyrehead webpage they posted the front spring P/N as:
22077196
and the rear as
22132889
Here is a quote from a post on LS1 tech's page:
GM no longer stocks 1LE springs. If you order the 1LE part number, they substitute the base spring.
I can find very little info on what the mysterious p/n 22077196 front springs are. Best as I can tell they are the WS6 and probably the Z28 stock front springs. (Didnt see that P/N on shoe's P/N page).
Old Oct 6, 2004 | 09:11 PM
S8ER95Z's Avatar
Re: 1LE option
http://www.ls1tech.com/forums/showthread.php?t=27999
Appears to be WS6 springs.
Old Oct 7, 2004 | 08:12 AM
kevm14's Avatar
Re: 1LE option
Were Bilsteins ever used?
Old Oct 7, 2004 | 08:56 AM
97-1LE's Avatar
Re: 1LE option
For your 96 you should have the folowing
2- front shock absorber- Koni Yellow 22140240
2- Rear shock absorber- Koni Yellow 22140228
intake elbow w/o silencer 25147187
2 front springs LT1 360 # 22132561
2 rear springs LT1 130/170 # 22132562
Transmission mount 22146231
Front sway bar 32mm 26032907
Front sway bar bushing 32 mm 26039956
2 rear lower control arss 10164151
rear panhard bar 10262147
right upper control arm 22145654
left upper control arm 22145653
right lower control arm 22156436
left lower control arm 22156435
If you have the decarbon shocks they are probally from 94/95 part #
front 22124758 or 22140190
rear 22124790 or 22140187
Old Oct 7, 2004 | 10:40 AM
bozobuttz's Avatar
Re: 1LE option
1LE front spring = 360lb spring
360lb spring = part # 22077196
therefore, 1LE front spring = part # 22077196
. I dont see what all the confusion is about.
Old Oct 7, 2004 | 01:05 PM
"White Knight"'s Avatar
Re: 1LE option
1LE isn't that much better I don't see why people buy that stuff. buy a good peice of hardware, cause basically your buying stock parts. If your shocks are blown then yea buy them but don't take off perfectly good shocks and put 1Le shocks on, from what i hear about them they feel almost no different other than a mental difference.
