1LE elbow opening size?
Old Jul 30, 2006 | 09:17 PM
ChronoGN's Avatar
Does anyone know the diameter of the opening on the 1LE elbow? I'm thinking about using the 1LE elbow for a custom turbo application and from what I remember, it was 3" which I'm hoping it is. But then again, I remember it being bigger than 3" Anyone know for sure?
I'm trying to get a 3" intercooler pipe to go into it.
Thanks!
Old Jul 30, 2006 | 11:25 PM
Re: 1LE elbow opening size?
It's the same as the regular elbow.
Old Jul 31, 2006 | 09:05 AM
ChronoGN's Avatar
Is the stock elbow 3" ID?
Right now, I have a 2.5" to 3" silicon connector going into the throttle body so, I don't have a stock elbow to take measurements off of.
Old Jul 31, 2006 | 10:07 AM
Many of us have used the Fernco 3"x3" sewer pipe connector to run from the MAF sensor to the throttle body. The Fernco is actually 3.38" inside diameter, and fits like a glove, at least after you soak it in hot water to soften it enough to go around the oval throttle body.
Old Jul 31, 2006 | 10:09 AM
1SlowFormula's Avatar
Are you looking for at the TB or at the MAF?
I have a 3" coupler going between the MAF and TB, it fits correctly over the MAF and needs to be streched a little to get around the TB but it works...
This makes me think the MAF end is 3" and the TB end is like 3.25" or so...
Old Jul 31, 2006 | 10:19 AM
anaik's Avatar
Just measured my stock elbow. The ID on the end that connects to the MAF is 3.5".
Old Jul 31, 2006 | 10:32 AM
Whoops, well I guess since my coupler is the fernco too, it really isn't 3" like it states, as Injuneer and anaik proved. But I hope this helps you figure out what you need to do...
Old Jul 31, 2006 | 02:52 PM
ChronoGN's Avatar
Cool, thanks guys.
HectorM52
Jul 30, 2017 11:46 AM
Pampered-Z
Apr 14, 2015 05:38 PM
gto4u2
Mar 14, 2015 06:05 AM
Jason Short
Jan 19, 2015 06:34 PM
