1997 Z28 - pulled driver valve cover - Issue finding where a (small) vacuum hose goes
Old Feb 9, 2010 | 05:57 AM
Dave_A's Avatar
Ok, I'm chasing a rather bothersome noise & random-misfire code, that I believe to be a top-end problem...
To do this, I pulled my driver-side valve-cover, to check if I had any rocker or spring damage... None evident.
In the process, I disconnected a very, very small vacuum hose that appears to follow the wiring harness (the one that runs along the side of the valve cover) down the front of the engine.
Where does this thing go to?
Old Feb 9, 2010 | 07:10 AM
wrd1972's Avatar
Sounds like OPTI suction hose if its about the diameter of a pencil.
Runs from the left side of the intake, from a nipple to the optispark.
Old Feb 9, 2010 | 10:50 AM
Or the EVAP canister purge line.
Look at the vacuum routing diagram on the radiator cover.
Shoebox has an example:
http://shbox.com/1/emission_hose_routing.jpg
Old Feb 10, 2010 | 05:14 AM
Dave_A's Avatar
About the diameter of an electrical wire, but not a wire - a hose...
Will post pics tomorrow.
Old Feb 10, 2010 | 09:10 AM
There is also a vacuum line that was added as part of the AIR system recall.
Courtesy of Shoebox:
http://shbox.com/1/air_pump_recall.jpg
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
