possible IAC bad?
Old Feb 8, 2010 | 02:00 PM
conor.davis's Avatar
possible IAC bad?
my car started to take a few more cranks then normal to start a long time ago. now that its cold out it will start and if i dont keep it up at least 1500 RPM for about 20 seconds it will die. i was thinking it might be IAC so i tested resistance and that was good, took it off sprayed some carb cleaner on it and cleaned TB. didnt do anything. i didnt force the IAC to move i didnt know if i could break it. anyone think it could be stuck or bad? i replaced TPS sensor too (need to check voltage again). fuel pressure was alright last time i checked. thanks guys.
Old Feb 8, 2010 | 02:01 PM
also its a 94 new plugs wires msd cap rotor and MAF is clean
Old Feb 9, 2010 | 08:33 PM
OneShoe50's Avatar
You knon those IAC's can really react slow when dirty giving those symptoms and can be damaged with the wrong cleaner.
I would also search for ANY vacuum leaks that could also give you similar symptoms.
Old Feb 10, 2010 | 06:20 PM
havent found any vacuum leaks and i cleaned it with carb cleaner wich is safe on IAC... maybe ill find someones iac to borrow and try that before i buy one from a auto part store for $70
Old Feb 10, 2010 | 09:14 PM
OneShoe50's Avatar
+1 on the borrow, I have 2 of them and I always keep one clean and ready to swap when it acts up.
Xiantyl
Jul 21, 2015 05:42 AM
Jmj93z28
Jul 10, 2015 06:37 PM
Boss002
Jul 9, 2015 03:33 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
