1997 z28 engine harness ( clickable )
Old Feb 4, 2024 | 10:58 AM
weedog's Avatar
Does Anyone Have A 1997 Z28 Engine Harness Clickable. I Found 1 For A 1995 Z28 A4 Engine Clickable. Been Working on This 1997 Z28 5.7 For Over 3 Years Now. Should Get My Motor Out of The Speed Shop The 20th. Its Been A Long Process. Thanks
Old Feb 4, 2024 | 02:55 PM
Re: 1997 z28 engine harness ( clickable )
Rob/Shoebox noted that there are some changes for the 97. If you look at his pinout charts of the 1995 PCM connectors, he has added the 96/97 changes in red. There are 7 additional wires - 4 for the after cat O2 sensors, and one each for the crank position sensor, the EVAP vacuum switch, and the serial connection to the DLC. Given the location of each item being readily available, comparing Rob's clickable 95 harness to your 97 harness should make it easy to identify the locations of the new connectors.
I'm not aware of anyone doing all the work to produce a clickable harness for any other years. We're fortunate that Rob put all the work in to produce the 95 product.
4th Gen LT1 F-body Tech Articles
https://www.camaroz28.com/forums/lt1...arness-889940/
Old Feb 16, 2024 | 09:38 PM
weedog's Avatar
thanks Injuneer
weedog
Jan 25, 2024 08:41 AM
2nd_chances
May 31, 2014 12:34 PM
qnitro
Parts Wanted
Jan 5, 2010 01:51 PM
civicman
Sep 5, 2003 10:12 AM
