1997 Z28 Engine swap ?
Old Sep 5, 2003 | 09:16 AM
civicman's Avatar
Question 1997 Z28 Engine swap ?
For my 18th birthday, my dad bought me a 1997 Z28 and it seems to be a bit sluggish. My buddy has a V-tech available for sale. If I were to remove my old engine and lower that in my camaro would that produce much better results? The engine he is offering is supposedly a 4-cyclinder and I think it produces around 325 hp.
Old Sep 5, 2003 | 09:22 AM
Scotts94z28's Avatar
Angry
THAT WOULD BE A GODD@MN DISCRASE.
That would be no different than getting some spray paint to the ceiling of the Sisteen Chappel, or drawing a mustache and nose hair on the Mona Lisa.
Old Sep 5, 2003 | 09:28 AM
bandit_1981's Avatar
Dude, the engine in your z28 has a nice starting horspower number that can be raised pretty easily, maybe not cheap but easy. Stick with the LT1.
Old Sep 5, 2003 | 09:42 AM
Terran2k's Avatar
dont ruin the car like that, trade it in and get a civic, or sell it and get a civic.
Old Sep 5, 2003 | 09:43 AM
jd94z28's Avatar
First off have you Z checked out. There are many possible simple maitenance items that can cause the engine to lag.
Second, its VTEC. Any, 4 cyl. that is putting out 325HP is going to be high maintenance. The engine will probably blow within 6 months. Don't give me any crap about not knowing Honda engines, I also have a '99 Prelude SH.
Third, it would be extremely expensive to try to place a Honda engine in a Camaro. You would first need to figure out how to mount the transverse engine. Then you would either need to find a rear drive transmission that can mate with the rear end. Or, completely rework the front to be front drive.
I would say a ball park cost for this conversion to be 10K-15K.
Sticking with the original engine for 10K you could have a reliable all motor car with over 450 RWHP. Much more if you opt for a supercharger.
Stick with the original block.
Old Sep 5, 2003 | 09:48 AM
civicman's Avatar
Yeah I guess that is a good point. 325 HP for a 4 cyclinder is pretty hot to run on. Thanks for the advice.
Old Sep 5, 2003 | 09:54 AM
87transam383tpi's Avatar
also too w/ 4cyl engines you may have 325hp but half the torque probably of the Z28........ something to think about numbers aren't always everything.
Josh
Old Sep 5, 2003 | 10:03 AM
95camaro z28LT1's Avatar
You would be a fool if you did this. You would ruin the image of your domestic car.
Remember 8 cylinders engines has four more cylinders which=MORE POTENTIAL HP
jd94z28's Avatar
No matter what the import crowd says, anthing they can do we can do better. We have the one thing they can never just bolt on, displacement!
Old Sep 5, 2003 | 10:12 AM
Brent94Z's Avatar
Super Moderator
I think you got your answer. I'll close this before it gets outta control
ScottZ
Mar 3, 2004 01:34 PM
turbo_Z
Aug 19, 2002 10:50 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
30thZ286speed
Aug 3, 2002 04:54 AM
