1996 Z28 timing
Old Nov 2, 2022 | 04:36 AM
Silver_96_Z's Avatar
1996 Z28 timing
I have a 1996 Z28 115,000 miles basically stock. opti went out while Im there I'm putting a new timing chain set. Just to make sure and cover all my bases when putting the crank gear and cam gear on I put the cam gear at 12 and crank at 12 for TDC #1 and should be good to go?
Old Nov 2, 2022 | 09:25 AM
Re: 1996 Z28 timing
Shoebox has a detailed cam install procedure. Scroll down to the timing chain section (install cam sprocket):
4th Gen LT1 F-body Cam Install
Old Nov 2, 2022 | 09:48 AM
Re: 1996 Z28 timing
12 and 12 is fine, but easier to tell if they are lined up at 12 and 6. Either way works.
Old Nov 2, 2022 | 11:03 PM
GaryDoug's Avatar
Prominent Member
Re: 1996 Z28 timing
Are you implying that the cam rotates at half the rate as the crank? Weird ;-)
Old Nov 3, 2022 | 06:40 AM
Re: 1996 Z28 timing
So you say it won't work?
Old Nov 3, 2022 | 08:16 AM
Re: 1996 Z28 timing
Yes
It will
http://shbox.com/1/cam_timing_ani.gif
Old Nov 3, 2022 | 10:45 PM
GaryDoug's Avatar
Prominent Member
Re: 1996 Z28 timing
No....sorry it was a bad joke ;-) <<<< note the wink!
orange94z28
Sep 17, 2007 09:16 PM
93BlackTA
Feb 22, 2007 06:50 AM
R_Andersen
Mar 30, 2004 06:58 PM
niteninja
Feb 6, 2004 06:38 AM
grendal
Jun 30, 2003 11:59 AM
