1995 z28 code 41 after header installation
Old Mar 7, 2013 | 08:09 AM
yanal_13's Avatar
I have a 95 z28 6speed and i installed headers long tubes pacesetters couple of days ago and i started to get code 41 on my car i know this code is related to the ICM or cam sensor or open circuit
When i put theaders i broke the temp gage sensor and i didnt put one in yet and i also took off the o2 sensors due to reach till i extend them.
One more thing there was a wire between the ground and the old exhaust manifold i didnt connect. Could that be the reason to get open circuit code?
Old Mar 7, 2013 | 02:13 PM
ACE1252's Avatar
Re: 1995 z28 code 41 after header installation
This links to another forum, but there are factory manual snapshots for your code(and all the others too....)
OBD1 DTC Codes & Troubleshooting - LS1TECH
Old Mar 7, 2013 | 02:31 PM
yanal_13's Avatar
that is great thanks
Old Mar 7, 2013 | 07:02 PM
yanal_13's Avatar
could that be related to the o2 sensors because i didnt put them on yet?
Old Mar 8, 2013 | 01:17 PM
ACE1252's Avatar
I doubt it. Follow the troubleshooting chart on 41_2. That should help out, however if the problem is intermittent, that could be more of a challenge.
Old Mar 8, 2013 | 08:11 PM
yanal_13's Avatar
the thing is that the code comes out after about 10-15 min i tried to turn the car of and turn it the code went away for about the same time. i tested the voltage on it was fine it was 4.8V so the ICM is fine
it is confusing me and now i started to get a lifter knocking sound some times depends on the cars mode
all that killed my happiness after the headers
Old Mar 13, 2013 | 08:41 PM
yanal_13's Avatar
i just finished fixing my car i found the starter wire is hitting the headers and 2 spark plugs wires also hitting them on both side it damaged my starter i put all the sensors back in and the car felt like a monster i never felt it like this before it was awsome to drive
thanks for the help
Garcia5
Jul 7, 2022 06:51 PM
calaban
May 18, 2020 06:43 PM
Jan 5, 2015 07:14 PM
pete53
Dec 9, 2014 07:31 AM
MJ_Z28
Aug 7, 2002 07:15 PM
