1995 Z28 Auto will not crank
Old Aug 6, 2014 | 10:04 PM
  #16
Re: 1995 Z28 Auto will not crank
The switches are different because the auto one has a provision for the park/lock cable. The manual trans does not. Function should be the same otherwise.
Old Aug 7, 2014 | 01:05 PM
  #17
Tj.Rafferty's Avatar
Well starter is good, ran the test at Autozone 4 times to make sure.
So now I know it's definitely a wiring issue somewhere.
When my buddy gets off work I'll start checking all the power wires. If they are all working properly then I'm assuming I need to replace battery cables and all?
Old Aug 7, 2014 | 09:33 PM
  #18
Ok, while hooked up this this is the read out of the following;
Yellow wire connected to the starter relay: 12.36V
PCM to battery fuse 4: 11.89V
Crank fuse 16: 11.45V
PCM to ignition fuse 5: 12.21V
Purple wire to starter: has no power going to it
Red wire to starter: 12V
With that being said, I'm assuming it's something in the VATS system?
Like me needing to ground out the yellow/black wire in the TDR?
Now the starter was OFF the car while I tested that purple wire, not sure if that would make any difference in it at all
Old Aug 7, 2014 | 10:09 PM
  #19
The purple wire to the starter should only have 12v on it with the key in the start position. That is what engages the starter and kinda the whole point of testing it.
Old Aug 7, 2014 | 10:26 PM
  #20
Awe man, I'll put the starter back on this weekend and test the wire again.
I was hoping it didn't matter
Oh well that's that I get for not thinking
Old Aug 8, 2014 | 07:57 AM
  #21
You can test the purple wire with the starter off. Just don't let it touch any ground when the key is in the start position.
Old Aug 8, 2014 | 12:15 PM
  #22
Ah ok, that's what I did and the Purple wire doesn't have power going to it when the key is in the start position
Old Aug 8, 2014 | 01:44 PM
  #23
timnfxr's Avatar
The +12v on the purple wire comes via the TDR contact when energized, which is when the neutral safety switch is in the P/N position, and ignition switch in the Start position.
Is the NS switch connected?
Old Aug 8, 2014 | 02:12 PM
  #24
Yes, the switch is connected
Old Aug 8, 2014 | 04:04 PM
  #25
We're back to the yellow wire from the ignition switch. Check the yellow wires that attach to the TDM... terminal C1 for the load side of the relay, and terminal C2 for the signal side of the relay. Should have 12V on both, with key in "start" position, trans in park.
Old Aug 8, 2014 | 04:51 PM
  #26
Alright, the yellow does have 12V when the key is in the start position. I can tell you that much right now.
Nevermind I read that a little wrong. I'll check the relay here in a minute.
Old Aug 8, 2014 | 06:18 PM
  #27
You really have to keep an open mind to get help.
Old Aug 8, 2014 | 07:12 PM
  #28
I know, these last few days have been long and draining.
I just need to wait to check back on replies and do the suggestions when I'm not tired and I have a clear head.
Lesson learned
Old Aug 8, 2014 | 09:20 PM
  #29
Wait is there a difference between the theft deterrent module and the theft deterrent relay? Everything I've seen so far has shown the TDR/TDM on the inside of the dash by the airbag.
If that's it, then there is no voltage to the wires at C1 or C2 with the ignition in the start position and transmission in park
Or am I following part of the harness up into the dash on the right of the radio and squeezing my big *** hand into that space for a hobbit to find a module? Because that's the only part of the harness I can see that has 2 yellow wires mixed with purple and a few others
Old Aug 9, 2014 | 09:59 AM
  #30
Reference Shoebox's 95 starting system wiring diagram - link already provided in an earlier post. It shows the TDRelay with two yellow wires on the supply side, and a purple wire to the starter and a yellow/black "activation" wire from the TDModule.
I've never had to access these components, but the 1994 factory manual shows the TDR and the hatch relay being to the right of the glove box. Check there. I have no idea if 94 and 95 are the same, or if I am even reading the manual diagram correctly.
