1995 - No Spark, No Fuel
Old Aug 10, 2013 | 02:08 PM
x2dz's Avatar
I am getting no spark and the fuel pump is not kicking on.
The computer was replaced after it shorted out the battery. The computer was full of water from the prom cover not being tight. Replaced computer with a new one. Still no spark or fuel. Tried connecting the laptop for pcm signal but no signal.
Any advice?
Old Aug 10, 2013 | 03:39 PM
Re: 1995 - No Spark, No Fuel
Did you check the PCM fuses?
Old Aug 10, 2013 | 04:26 PM
x2dz's Avatar
yep first thing I did.
Old Aug 10, 2013 | 05:11 PM
slick1hunting's Avatar
I had the pcm ign fuse not making contact before yet fuse was not blown. I had same symptoms fuel pump not kicking on and could not connect to pcm.(didnt check for spark) Might be worth double checking the 2 pcm fuses and even testing for power in the fuse box. Have you had it operating correct after changes?
Posted from Camaroz28.com App for Android
Old Aug 10, 2013 | 06:40 PM
timnfxr's Avatar
Have you checked Fuse 8 (15A) marked "Courtesy" on the interior fuse block?
It is one of the power sources to the theft deterent system.
Old Aug 10, 2013 | 07:18 PM
When you turn the key to run, do the dash warning lights come on for a few seconds to verify they are working?
Garcia5
Jul 7, 2022 06:51 PM
calaban
May 18, 2020 06:43 PM
joe777107
Dec 1, 2014 09:32 AM
Jul 4, 2005 05:00 PM
