1995 camaro z28 5.7
Old May 11, 2011 | 02:50 AM
darryle's Avatar
1995 camaro z28 5.7
my camaro stalls sometimes i can drive the car for 2 days no problems but then it will stall on the 3rd day will start right up then stall again and then it wont start up 1hr later the car started up and ran,(this happened several times) but i was to nervous to drive home so i had it towed ... ive had a new optim spark ign. istalled 2 years ago (accel. brand) my fuel filter replaced fuel pump replaced,fuel regulator replaced cold air intake replaced all this year and it still stalls please any suggestions?
Old May 11, 2011 | 03:14 PM
94QuasarZ's Avatar
Re: 1995 camaro z28 5.7
You could possibly have a leaky EGR. Start by looking on the driver's side of the intake plenum and make sure the hose that runs from the top of your EGR to the plenum is not loose or disconnected. If it is, or if that doesn't solve your problem, I'd replace the EGR.
Old May 12, 2011 | 07:37 AM
Could be many different problems - faulty idle air control (IAC) valve, faulty coolant temp sensor in the water pump housing, corroded terminals on the short Opti harness, loose wiring to the ICM, loose engine or PCM grounds, problems with the Accel Opti (not a good choice). First step is to have it scanned for codes. Second step would be to check the fuel pressure.
EGR sticking open will cause it to stall, but the EGR won't stick open because of the vacuum line being disconected or broken.
NewsBot
Dec 28, 2014 06:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
Chrisdude
Jul 24, 2002 02:25 PM
Jake77444
Jul 21, 2002 05:37 PM
