1995 camaro exahust problem
Old Feb 14, 2011 | 06:03 PM
  #31
chris_14kingz28's Avatar
Re: 1995 camaro exahust problem
where can i get those O2extensions ?
Old Feb 14, 2011 | 06:20 PM
  #32
Originally Posted by ACE1252
I can verify that a Jet Hot coating will take out O2 sensors. I just had one throw a code. With info from here, I was prepared for it and it simply killed the old O2 sensors I installed in it.
I proposed this theory about 4 or 5 years ago on the "Advanced Tech" forum, but so far I haven't found anything except anecdotal evidence to support it. Someday I'd like to figure out what is used in the cera-metallic coatings that poisons the O2 sensors. So... to avoid being accused of spreading internet rumors as I was recently, I use the term "some evidence"..... thanks for the additional info.
Old Feb 14, 2011 | 06:54 PM
  #33
ascastil's Avatar
http://www.adaptiveperformance.com/o2ext.htm
there might be some cheaper out there, this was just a quick google search. i forgot where i got mine.
Old Feb 14, 2011 | 06:59 PM
  #34
ascastil's Avatar
oh yeah, i hope you made the wiring on the actual o2 sensor longer, and not the wiring on the pcm side, if you did, whoops!
Old Feb 14, 2011 | 09:59 PM
  #35
Actually, its the other way around. Extend the factory wiring hanress. Don't cut/splice the stainless steel sensor wires.
Old Feb 15, 2011 | 05:53 PM
  #36
i ran the car thru a scanner and nothing came up. and i went and talked to a freind who works lt1s and he said i needend a cat.. caouldent i get the car tuned for not having a cat?
Old Feb 15, 2011 | 10:51 PM
  #37
Your 95 is OBD-I, and has no way of knowing if the cat is there or not - there is no after-cat O2 sensor like there is in OBD-II. There is nothing to "tune".
Old Feb 16, 2011 | 05:28 AM
  #38
my car is a 1995 but the guy i bought it from took a motor out of a 1996 lt1 and the computer and everythang and swaped it to my car. i have and OBD-II computer in my car
Old Feb 17, 2011 | 12:13 AM
  #39
Procharged94Lt1's Avatar
I know you said you tied back the plug wires but how new are they? If they are a few years old I would replace them- they are cheap enough. In the midst of removing/re-installing the headers and such you might have messed up one of them and now its not working like it should.
As far as your computer it still shouldn't cut the power without a cat in it. Something is obviously wrong if you car has the ORY, OBD-II and you aren't throwing any codes. If nothing else it should be throwing a code for the missing o2's. Is there wiring for 4 02 sensors or just 2? If you have just 2 I have a feeling you were lied to.
Old Feb 17, 2011 | 02:21 AM
  #40
Fatdog2's Avatar
Originally Posted by Slick-Z
If the engine is stock then you should go no bigger than 1 5/8 headers if you have the 1 3/4 inch headers then you will hardly get any back pressure at all. This is a common problem just wondering if this is the setup you have due to you not giving that much info. Also from 95 to 96 they went from single cats to dual so if you have no cat and three inch piping diameter or smaller then theres no problem. But you cant go more than 1 5/8 headers and 3in piping or you will have alot of blow buy exhaust with no buildup for back pressure. So good luck buddy.
You read this as well as I did in Hot Rod Mag,when they tested the small block Chev engine.The 1 5/8 tubes were very acceptable.Don't know why though.My02.
Old Feb 17, 2011 | 06:53 PM
  #41
ACE1252's Avatar
No problem. I'm not sure what was used myself, but I can tell you that it smelled pretty bad. When the headers came up to temp in my garage, the car started to smoke something serious. I mean some thick white smoke. It actually made me sick on my stomach. I had to shut the thing down and let the garage air out. I then moved it outside to let it finish burning off. All told it smoked for around 15-20 mins and smelled really bad for about a week after. I do have the cat'd y-pipe, so something in there may have been burning off too.
About three weeks of running it after the header install, I got a code P0134 - Heated Oxygen Sensor Circuit Insufficient Signal Activity Bank 1 Sensor 1.
I swapped in all my new AC Delco's and am praying that all the stuff that needed to be burned off has been burned off.
The Jet Hot flyer claimed that it would not hurt the O2's...but I can't believe it. Those O2 sensors may have been used, but they were perfectly fine when I took them out of service(to save for header install).
Edit:Well I thought the flyer said that....I've gone over it again and can't find it...I know I read that from them somewhere....
Garcia5
Jul 7, 2022 06:51 PM
calaban
May 18, 2020 06:43 PM
joe777107
Dec 1, 2014 09:32 AM
SLIMJIM
Jan 7, 2003 11:06 AM
Chrisdude
Jul 24, 2002 02:25 PM
