1994 z28 does not start but "clicks" no security light
Old Feb 8, 2006 | 05:17 PM
bstieboydp's Avatar
i know its been asked before but im stumped on this one
the car makes what seems like a bunch of clicking noises simaltaneously when i try to start it and does this over and over i replaced the batttery today with a brand new red top optima same thing, the fuel pump does prime and everything in the car works (power seat/accesories/locks etc) the noise seems to be coming from the right side by the glove compartment (which i believe is where the vats is? im not sure) i get no security light however.. if it is vats how would you fix that anyway? it seemed to happen all at once however this happened to me about a month ago but started after like 3 tries and then it happened again last week now this time it is stubborn and no matter what will not turn over.. thanks for the help guys
Old Feb 8, 2006 | 05:22 PM
jrock514's Avatar
Re: 1994 z28 does not start but "clicks" no security light
sounds like a bad connection or bad starter check and clean wires to the starter and bat. and if not that pull starter and have it tested
Old Feb 8, 2006 | 05:41 PM
bstieboydp's Avatar
thanks for the quick response thats where i was headed for tomrow im going to pull the starter and have it tested at autozone (hopefully they test them i know they test other stuff)luckily i have my 87 camaro beater to get to work so its really not an emergency but my headers arrive this friday so maybe it is
Old Feb 8, 2006 | 05:49 PM
blkchevyz's Avatar
try giving the start a few taps with a hammer.
also might want to have the battery tested.
Old Feb 8, 2006 | 06:23 PM
bstieboydp's Avatar
brand new optima red top battery ill try knocking the starter and checking out all connections tomroow though thanks
Old Feb 8, 2006 | 07:07 PM
96ZCamaro's Avatar
Another vote on the starter here
Old Feb 8, 2006 | 07:18 PM
bstieboydp's Avatar
yea .. only wierd thing is besides the intermittent issues i explained i never had any grinding or anything but idk if starters on lt1 tend to grind or not before they go.. well see tomorow
Old Feb 8, 2006 | 09:27 PM
Jump the posts at the starter and see if it cranks.
Old Feb 8, 2006 | 10:05 PM
got8?'s Avatar
the solenoid isnt holding the plunger down, that is what that clicking sound it jump the two post on the solenoid and see if it will start
Old Feb 8, 2006 | 10:06 PM
resurrectedz28's Avatar
I believe i had/have this exact same problem. It was intermittent for awhile and then one day it wouldn't turn over anymore, just clicked, kept trying and finally something fried and no more clicking. I assumed starter solenoid and was wrong. Tested starter-it was good. Jumped it, got nothing. Finally had some people come over with a voltmeter and chase the volt current around, and it finally ended up under the passenger side dash.
I still don't know what the problem is (i "think" its the vats solenoid but i really don't know), but my solution (probably not recommended/smart) was to run a wire from the solenoid terminal and another from the battery to a fan switch on the inside that im not using, turn the key on and flip the switch to start it.
Hey, it starts the car. Good luck with it.
PS never had a security light. 93 z28 auto.
Old Feb 8, 2006 | 10:07 PM
Jameslt1TA's Avatar
I have to do that to get mine to start every now and then...the damned silenoid always sticks...and for 70 bucks i would rather open the hood, pull out my bailing wire and jump it over the the purple starter wire that has just a small amout stripped off.
Old Feb 9, 2006 | 04:05 AM
grandnational007's Avatar
I am experiencing this right now and it's pissing me off!
when you say no security light, do you mean that it does not blink when you go to start it, or it does?
I have a feeling I killed a solenoid or starter when I attempted to jump start it the other day off my roomate's truck. I also just put in a new battery today, and the clicking from the glove box can be heard too. let me know if you figure it out, and vice-versa
also, can you jump a m6? If so, how?
Old Feb 9, 2006 | 06:03 AM
Jameslt1TA's Avatar
By jump i assume you mean jumper the starter over to get it to start. Same as an a4 just touch the two termenals on the solenoid together....just make sure you dont touch your wrench or srewdriver on something metal, it make lots of sparks lol.
Old Feb 9, 2006 | 06:05 AM
Jameslt1TA's Avatar
Another thing you can try is to have someone hold the key in the position to turn it over...while you tap on the starter solenoid. Btw have it on jack stands and make sure it is steady before you try this. Also if you have open headers, it will scare the **** out of you when it starts.
Or you could fork over the 70 bucks and buy a new soleniod or 230 or so for a new starter.
Old Feb 9, 2006 | 05:15 PM
bstieboydp's Avatar
thanks for all the help guys i got home too late from work today to give it a shot and its dark already and freezing so im going to try tomorow with help from my dad so we can trace this problem down.. does someone have a picture of the starter selonoid? what do you do just run a wire from one post to the other to jump it? not exactly sure what guys mean by jump it but i didnt really even look at the starter itself yet so it might be clarified when i look at it
